Page 1 of 2
				Glow Plugs
				Posted: Tue Nov 29, 2011 7:00 pm
				by Smeeagain
				I have a 2004 E53 X5 - 2 of the glow plugs are showing up as problematic on the scanner (starting is aloittle sluggish)
IS this an easy job for an amateur - I've done spark plugs before but never glow plugs
Only two are showing up on the sanner - how many are there and should they all be done - mileage is 115k and they've never been changed since I got the car at 72k
Thanks Smee
				Re: Glow Plugs
				Posted: Tue Nov 29, 2011 7:27 pm
				3-litre diesel in which case it's a straight six engine with one plug per cylinder.  Isn't it always the way!  First signs of cold weather and out come all the gremlins to play - Glowplugs, door locks, batteries.......
				Re: Glow Plugs
				Posted: Tue Nov 29, 2011 7:28 pm
				by Smeeagain
				easy to do ? Expensive ?
				Re: Glow Plugs
				Posted: Tue Nov 29, 2011 7:30 pm
				Fiddly, and I think they're of the order of £50 a pop (i'm not 100% on that though, and that may be the OEM price).  Never changed mine as I only got to 53k with the E53.
Have a look here:
http://tis.spaghetticoder.org/s/view.pl?1/04/94/95
				Re: Glow Plugs
				Posted: Tue Nov 29, 2011 8:22 pm
				by x555
				Did this a while back and the glow plugs were £18.59 each before vat and there are 6 as X5Sport said. Not the easiest of jobs this one as the inlet manifold has to come of iirc.
Dont think i did a how to on this but may have some pics to help amongst my threads.
				Re: Glow Plugs
				Posted: Tue Nov 29, 2011 8:24 pm
				by x555
				Here ya go
   viewtopic.php?f=8&t=1106&hilit=+glow+plugs
BTW worth replacing them all as it's quite labour intensive to get them done
				Re: Glow Plugs
				Posted: Tue Nov 29, 2011 10:32 pm
				by Smeeagain
				yes just worked out that it was worth having all done if inlet manifold has to come off !!
thanks
				Glow Plugs
				Posted: Tue Nov 29, 2011 11:46 pm
				by dirtymonkey29
				Mine need doing too... Shopping list is getting longer
				Glow Plugs
				Posted: Wed Nov 30, 2011 12:10 am
				by Rusty
				Jason's lot did mine, all six ( five were showing faulty via INPA ) when he did the injectors.  It started fine before, but better after. Def worth doing.
You done yours yet Sanj?
				Re: Glow Plugs
				Posted: Wed Nov 30, 2011 6:37 am
				by Mrgee
				Had the same only after a week of buying the car, a warning about injectors came up on the dash. Took it back obviously, but I didn't fell anything different in throttle response and starting the car once the warning light came up. Made me wonder that if it was out of warranty, would I have changed them?
				Re: Glow Plugs
				Posted: Wed Nov 30, 2011 5:32 pm
				by Smeeagain
				Quote from trusted local (non bmw) garage
£64 plus for glowplugs.
Labour five hours - £187.50 plus vat
Basically £250 plus vat
Anything else I should get done at same time ?
				Glow Plugs
				Posted: Tue Dec 06, 2011 12:00 am
				by dirtymonkey29
				5 hours!!!!
				Glow Plugs
				Posted: Thu Dec 29, 2011 1:45 pm
				by dirtymonkey29
				All mine except no 4 are showing on BMW scanner along with the glow plug control unit.... Bugger
				Re: Glow Plugs
				Posted: Sun Jan 01, 2012 4:32 pm
				by Smeeagain
				I'd get them independently checked first. I've seen other posts here suggesting they needed replaced when they didn't. I'm no expert but if you have five out of six not working plus the control unit then you would struggle at the very least to start it if not impossible. Are you having problems starting ?
				Glow Plugs
				Posted: Sun Jan 01, 2012 5:18 pm
				by dirtymonkey29
				Nope no problems at all but it hasn't really been that cold yet.
