Page 1 of 4
				scanner 1.4.0
				Posted: Sun Nov 06, 2011 8:54 pm
				by malc1950
				Today i tried to download my scanners software on to my netbook on windows 7, also to my laptop on windows xp but it keeps coming up with a error box that keeps opening up again and again and you cant stop it, can anyone please give me any advise as i have been told it should be compatible with  windows 7 or windows xp
				Re: scanner 1.4.0
				Posted: Sun Nov 06, 2011 8:57 pm
				by shadrack
				where did you get the program from? im after it. thanks
				Re: scanner 1.4.0
				Posted: Sun Nov 06, 2011 9:02 pm
				by malc1950
				The software came with the scanner, also available on the Net
				Re: scanner 1.4.0
				Posted: Sun Nov 06, 2011 9:04 pm
				by shadrack
				oh whats it  look like, is that the one you can turn bulb warning etc off?
				Re: scanner 1.4.0
				Posted: Mon Nov 07, 2011 2:00 am
				by X MAN
				@ malc1950.  I followed these instructions and installed first time on my laptop running Windows XP
P.S     Follow instructions carefully.
http://www.resettools.com/quick_start_g ... etup_guide
@ shadrack. I bought mine from this UK Ebay seller
http://www.ebay.co.uk/itm/BMW-1-4-0-Sca ... 2c6080f0ca
				Re: scanner 1.4.0
				Posted: Mon Nov 07, 2011 10:42 am
				by malc1950
				Hi x man i used the same instructions as you but still have the problem of error message appearing over and over again with a beeping noise, my friend has the same proplem on his computer with windows xp, he thinks the problem is he hasent got service pack 3, so he is going to download it and try again, will let you know how we get on.
				Re: scanner 1.4.0
				Posted: Sat Nov 12, 2011 8:29 pm
				by malc1950
				Hi has anyone managed to download  scanner 1.4.0 software and drivers on to windows 7
				scanner 1.4.0
				Posted: Sat Nov 12, 2011 9:32 pm
				by dirtymonkey29
				Are you getting the error during install or after it's installed and trying to run it?  I seem to recall I had a similar issue trying to run the program after installing it and it not working.  I plugged it into obd port and ran software and it worked.  That was on my car laptop which runs vista business.
				Re: scanner 1.4.0
				Posted: Sun Nov 13, 2011 9:14 am
				by malc1950
				thanks dirtymonkey will give it a try later today
				Re: scanner 1.4.0
				Posted: Mon Nov 14, 2011 5:00 pm
				by malc1950
				5mths later and i am still not there but i wont give up , i have hit problems again this time with my scanner 1.4.0, over the weekend my friend managed to download the drivers and the software onto his laptop with windows xp as i only have windows 7 on mine , when we plugged it into the car the first page opened up and we did a scan on the car to find faults and then cleared them, but the problem is we could not find a way of getting into the page what will let me enable my heater on the OBC can anyone please help with advice, or if anyone near to Manchester wants to use my scanner they are welcome and hopefully they can help me out as well,
				Re: scanner 1.4.0
				Posted: Mon Nov 14, 2011 5:09 pm
				by x555
				[quote=""malc1950""]5mths later and i am still not there but i wont give up , i have hit problems again this time with my scanner 1.4.0, over the weekend my friend managed to download the drivers and the software onto his laptop with windows xp as i only have windows 7 on mine , when we plugged it into the car the first page opened up and we did a scan on the car to find faults and then cleared them, but the problem is we could not find a way of getting into the page what will let me enable my heater on the OBC can anyone please help with advice, or if anyone near to Manchester wants to use my scanner they are welcome and hopefully they can help me out as well,
I haven't got the car with me at the mo but i will plug mine in and take a look for you when i get chance in case i can help at all
				Re: scanner 1.4.0
				Posted: Mon Nov 14, 2011 5:14 pm
				by malc1950
				Thanks any help would be appreciated, i wont be able to try again till the weekend as my friend has it on his laptop
				Re: scanner 1.4.0
				Posted: Mon Nov 14, 2011 5:17 pm
				by x555
				I'll report back in due course
				scanner 1.4.0
				Posted: Mon Nov 14, 2011 6:42 pm
				by dirtymonkey29
				From memory you double click on ike and then open coding or reprogram or something assuming your looking for aux heating.  Have you tried 12v to pin one... Not many work as aux heater for one reason or another that I'm still trying to solve
				Re: scanner 1.4.0
				Posted: Mon Nov 14, 2011 7:31 pm
				by Waka
				I've got scanner 1.4.0 working on my Windows 7 ultimate netbook. I can't remember how I did it but it definitely works
I think if you go to device manager with the scanner plugged in to the X5 you should be able to update the driver from the ones supplied on the cd.
