Parking sensor sensitivity
dirtymonkey29
Post by dirtymonkey29 » Wed Nov 02, 2011 2:58 pm
Hi, I have a friend with an e46. Just had a rear sensor replaced but he seems to think the sensitivity or area of proximity has dramatically reduced. Can the range be altered with BMW scanner or navcoder?
fenj66
Re: Parking sensor sensitivity
Post by fenj66 » Wed Nov 02, 2011 3:35 pm
bmw scanner 1.4 certainly can adjust the distances on my x5. :)
x555
Post by x555 » Wed Nov 02, 2011 9:24 pm
[quote=""fenj66""]bmw scanner 1.4 certainly can adjust the distances on my x5. :)[/quote]
+1 ...i haven't messed with it apart from disabling the fronts but it can be done :thumbsup:
dirtymonkey29
Post by dirtymonkey29 » Wed Nov 02, 2011 11:17 pm
Why would you disable the fronts?
fenj66
Post by fenj66 » Thu Nov 03, 2011 10:22 am
[quote=""dirtymonkey29""]Why would you disable the fronts?[/quote]
I disabled my fronts also. The reason- one of the front sensors was faulty meaning no sensors worked front or back. Because I never need front sensors and their so awkward to replace, by disabling them completey, the backs work as normal again. So no more haywire sounds every time I select reverse.;)
dirtymonkey29
Post by dirtymonkey29 » Thu Nov 03, 2011 11:21 am
My front nearside sensor doesn't work but my rears do. I will replace it next year some time
x555
Post by x555 » Thu Nov 03, 2011 1:25 pm
Same as above mate ......i will get around to finaly sorting those front sensors one of the days :roll: but after having the bumper of about 10 times i got fed up with them :headbang:
Takson
Post by Takson » Thu Nov 03, 2011 11:19 pm
That's good to know. My front NS sensor doesn't work and the beep drives the war department nuts.
Hammy
Post by Hammy » Fri Nov 04, 2011 11:13 am
[quote=""fenj66""][quote=""dirtymonkey29""]Why would you disable the fronts?[/quote]
I disabled my fronts also. The reason- one of the front sensors was faulty meaning no sensors worked front or back. Because I never need front sensors and their so awkward to replace, by disabling them completey, the backs work as normal again. So no more haywire sounds every time I select reverse.;)[/quote]
Does make me laugh, because BMW only fitted the audible system, one sensor out = all sensors out. However, if you have an Intravee it gives you a graphical display for each individual sensor, why BMW didn't enable that themselves is a mystery to me.
dirtymonkey29
Post by dirtymonkey29 » Mon Nov 07, 2011 12:23 am
Graphical display on nav screen?
RichardP
Post by RichardP » Thu Nov 10, 2011 12:21 pm
[quote=""dirtymonkey29""]Graphical display on nav screen?[/quote]
Graphical display with a bar and numerical display and indicator of the closest sensor on the High cluster or numeric display for each sensor on the Nav screen.
Sanj
Post by Sanj » Thu Nov 10, 2011 5:01 pm
dirtymonkey29
Post by dirtymonkey29 » Thu Nov 10, 2011 8:38 pm
So will need an intravee unit, kci cable and what ever cable to charge iPod/iPhone. What else can be done with an intravee? I was looking at getting a dice media bridge.
Sanj
Post by Sanj » Thu Nov 10, 2011 9:02 pm
Arrhh see, the interest builds... :poke:
You need the KCA-420i with BOTH cables and the Intravee.
What do you get:
1. Unlock
2. Mirrors folding on key/key out of barrel (OEM mirrors must be fitted)
3. PDC display on OBD
4. iPod song display on OBD
And a whole host of other features to do with the car, let alone the superior iPod interface...
dirtymonkey29
Post by dirtymonkey29 » Fri Nov 11, 2011 1:04 am
1. Unlock what?
