central locking
- Mother
central locking
Yesterday my wife noticed when we pulled away that her door wasn't locking (passenger front) as it normally does and the button stayed up.......it locks with the key ok but wont unlock with key or button in car, you have to manually pull the door handle inside to unlock it....any thoughts?
- stevox5
central locking
Sounds like the actuator/catch assembly mate not a totally uncommon problem.
Nice easy job though.
Hth.
Hth.
- Mother
Re: central locking
[quote=""stevox5""]Sounds like the actuator/catch assembly mate not a totally uncommon problem.
Hth.[/quote]
What do i have to do to fix it?
Hth.[/quote]
- stevox5
Re: central locking
You will need a new door catch/actuator unit , door pannel off , side airbag removed then three torque screws and a wiring connector and you will have it removed .
Quite streightforward if you are handy with the spanners, if not aprox 3/4 hrs work fora garage. if you do it yourself be minfull of the airbag( disconnect the battery first )
HTH
HTH
- Mother
Re: central locking
It started working again using the central locking button in car, but then a few hours later it wouldnt lock, then back to locking but not opening.....strange?
gchristofi
Re: central locking
I think that's fairly typical of the way these solenoids / actuators fail. Mine was intermittent at first and then died completely....
