Cleaned out my washer bottle & filters, but.........
Post by AW8 » Sat Oct 15, 2011 5:16 pm
............I think I damaged my levelling switch (low washer fluid level sensor).
Procedure : Undid 2 plastic nuts, unplugged & removed all motors, then unplugged & removed sensor. Then removed bottle and pulled out all filters in bottle cleaning same with old toothbrush.Used hose to rinse out bottle.
2nd time doing this & on resasembly I had washer fluid low warning. Assumption made I must have dmaged sensor by bending,knocking same.Tried carefully straightening sensor but no change. Tried again & promptly broke it :roll: at least it got rid of the false dash warning. :roll: New one ordered this morning............cost about a tenner for new BMW item.
Hopefully new sensor will sort matters otherwise I have damaged the floaty bit in bottom of bottle. I will know by next week.
So my advice.............Be careful not to cause damage when doing this simple job.
Phil D
Re: Cleaned out my washer bottle & filters, but.........
Post by Phil D » Sat Oct 15, 2011 6:14 pm
That sounds like the type of thing that happens to me!
Was it full of gunk?
2003 E53 - 4.4i Black with Black leather, Bluetooth/Sat Nav & Factory Xenons
Post by AW8 » Sat Oct 15, 2011 6:16 pm
Not too bad considering I have used tesco fluid albeit the strongest one not the cheapest - I prior cleaned it 3 years ago - car was then 6 years old - done less than 20k since then
Filters where a little clogged otherwise ok..........hard to clean inside bottle though.
fenj66
Post by fenj66 » Sat Oct 15, 2011 6:48 pm
the filters on my washer jets are constantly getting gunked up recently. i use halfords screen wash additive and have previously had the fluid tank off for a good washing out.
im thinking of throwing in some domestos too now to see if that might clear up the problem!
Post by AW8 » Sat Oct 15, 2011 8:28 pm
Thats might not bee too kind on the paintwork.
Many rave re qualities of the BMW screenwash.............especially in coldest of winter.
Not cheap though.
Maybe worth googling to looking at reviews, group tests &/or other info re decent fluids in cheaper branded bottles.
Post by X5Sport » Sat Oct 15, 2011 9:25 pm
Bleach on paint :o :o :cry: Not a good idea at all. It'll wreck the rubber too, even at very low concentrations.
You can get the BMW screenwash in 5-litre containers if you ask. With 3 cars all fitted with 6-8 litre tanks and filthy roads we do tend to use a fair bit, especially in the winter. The guy at the parts counter checked when I asked about bigger bottles than the standard 1-litre variety and he found the 5-litre option. Makes more sense as it's cheaper than buying 5x 1-litre.
I've never had a gunked pipe with BMW stuff whereas the Halfrauds 'Concentrate' kept blocking the tailgate nozzle on the E53. BMW changed it a couple of times under warranty.
Post by AW8 » Sat Oct 15, 2011 9:39 pm
What's the price for the BMW screenwash 1 & 5 litre ?
Post by AW8 » Sat Oct 15, 2011 9:41 pm
Just seen cotswold selling same £3.67 per litre
Post by X5Sport » Sat Oct 15, 2011 10:11 pm
I'll see if I can find the receipt.......
pvr
Post by pvr » Sun Oct 16, 2011 10:12 am
I bought it online (10 litres) from BMW as well.
... cheaper than a new floater and cleaning effort :poke:
Waka
Post by Waka » Mon Oct 17, 2011 10:06 pm
Best screen wash you get, as used by British Antarctic Survey, good to -60C!
http://www.lidl.co.uk/cps/rde/xchg//lid ... date=&ar2=
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
Post by AW8 » Mon Oct 17, 2011 11:56 pm
Link caused me to enter a postcode but product found............thanks.
My new levelling switch should be here by Thursday........I just hope I havent wrecked the float.
gobiman
Post by gobiman » Tue Oct 18, 2011 7:40 am
Thanks for the link.
The anti-swallowing additive is clearly a key selling point - just in case you fancy a pint of it while filling up.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Waka
Post by Waka » Tue Oct 18, 2011 12:16 pm
ooops, sorry about the link, although you can click on the 'continue without post code' button :thumbsup:
I guess the the bitrex is to stop our European friends adding it to their wine! :rofl:
Post by AW8 » Tue Oct 18, 2011 12:38 pm
