Low on power
Pradaman
Low on power
Post by Pradaman » Tue Oct 11, 2011 7:16 pm
Had my 55 plate x5 in for a service wife drove it back and said it felt low on power. took it round the block tonight and it feels very slow. It's a 3.0 d sport no lights are on any suggestions could there be a pipe off or something?
wilkoturbo
Low on power
Post by wilkoturbo » Tue Oct 11, 2011 7:32 pm
Have a look in the left hand side of the engine there is a black box with 2 tubes coming off it make sure they are on
bmw x5 le mans blue
EXPLORER
Re: Low on power
Post by EXPLORER » Tue Oct 11, 2011 7:42 pm
have they done engine breather/ seperator, check, they do it every third oil change
Re: Low on power
Post by X5Sport » Tue Oct 11, 2011 9:36 pm
Sounds like a vacuum hose is off. Common issue after a service as those hoses can get knocked. As has been suggested, check all the small pipes and hoses on the LHS of the engine area.
Pradaman
Re: Low on power
Post by Pradaman » Tue Oct 11, 2011 10:27 pm
Problem solved vacuum pipe off thanks very much for your advice guys. Bit peed off with the garage for putting it out like that!!? rant over!
jamesturner
Re: Low on power
Post by jamesturner » Wed Oct 12, 2011 11:06 pm
I had same fault after having some work done on mine, A worrying time as I kept thinking about Turbo replacement. Glad you are sorted now and appreciated the help from this forum in rectifying the problem.
Regards Jt
