Who made the diffs on the E53??
Steamyrotter
Post by Steamyrotter » Fri Oct 07, 2011 9:27 pm
As the auto box is a GM i am assuming BMW also bought in the diffs rather than design & manufacture themselves??
Anyone know the OEM for them if that is the case.
Also where can parts be obtained from rather than just general replacement????
amacman
Re: Who made the diffs on the E53??
Post by amacman » Sat Oct 08, 2011 3:33 am
As far as I recall the front diff is a VAG ( volkswagen audi group ) diff .
I have info somewhere but don`t know when I`ll have time to search .
rear diff may be usual bmw supplier , not sure on that .
JimmySpeed
Post by JimmySpeed » Sat Oct 08, 2011 8:29 am
[quote=""amacman""]As far as I recall the front diff is a VAG ( volkswagen audi group ) diff .
rear diff may be usual bmw supplier , not sure on that .[/quote]
Are you saying it's made by VAG, or are you saying VAG and BMW both get them from the same 3rd party company?
Post by X5Sport » Sat Oct 08, 2011 5:45 pm
The E53 front diffs were made by the Dana Corporation in the US from at least 2004 and possibly earlier, can't tell you if they made them or 'assembled' them from supplied part kits. If you can, get under the car and see if there is a factory label or mark in the case casting for the rears? It's possible that the rear may also be a Dana unit.
I can't remember how much of the X5 is covered with protective shields (the X6 is completely enclosed underneath and has a ZF/GKN Driveline system at the back).
amacman
Post by amacman » Sun Oct 09, 2011 1:58 am
Front diff is a VAG174 . I think the V is the German word vorderachse meaning front .
Rear diff is a HAG188K . I think the H is the German word hinterachse meaning rear .
see pages 28-30 on attached document
Drivetrain-Final Drives
The final drives for the front and rear axles are conventional differentials. The DSC system
provides anti-spin/slip control for both the front and rear axles on the X5.
The rear differential is the HAG 188K
(compact) unit with a ratio of 3.64 : 1
The front differential is the VAG 174
unit with a ratio of 3.64 : 1.
26530006
26530007
http://www.bawarec.ru/manuals/x5/e53/ma ... e53-10.pdf
I can`t say who actually manufactures the diffs .
