DSC 4x4 inactive
DSC 4x4 inactive
Hi Guys and Gals,
As the subject above says I keep getting the DSC 4x4 inactive lights on and message on the dash. If I drive nicely it doesnt come on but if I push it a bit ie getting out of a junction or overtaking then it comes on. Has anybody experienced similar and what did you do to overcome this. It has only been happening since I picked it up from the garage after my lots of smoke experience. I drive a 2005 3.0 diesel in estoril Blue
Appreciate any thoughts or remedies
Kind regards in advance
Jt
Jt
Re: DSC 4x4 inactive
It could just be a sensor not measuring the rotation of one of your wheels correctly meaning it thinks you are losing traction?
Turks.
Turks.
Present:
Past:
Past:
This could be a number of things but for me it was a wheel speed sensor (also known as a pulse generator) front nearside IIRC.
From memory it was about £50 from the dealers and took me about 5 mins to do
just need an allen key.
HTH
HTH
you really need to read the codes mate,could be nothing to do with the 4x4 at all
[quote=""strummer""]you really need to read the codes mate,could be nothing to do with the 4x4 at all[/quote]
Good advice that
could be anything with all the electrics on these cars
Good advice that
DSC 4x4 inactive
Had this exact problem back on February, mines turned out to be the transfer box/case. Only the dealer could fix it due to coding and the bill was £3000 and that was with discount.
Hopefully yours is only a sensor!
[quote=""x555""][quote=""strummer""]you really need to read the codes mate,could be nothing to do with the 4x4 at all[/quote]
Good advice that
I had it once although it's a long shot as the fault as the OP suggests no tinkering with steering
My steering wheel (after a track rod end replace) was slightly off centre. The x5 read this as infeasable steering angle...as in turning right whilst all wheels rotating equal as in going straight. This kicked out 4 wheel drive as yours does. Restart of engine temp fixed nd was diagnosed via the codes. straightened wheel and problem went away
my 2p worth
codes will reveal all
Mike
Good advice that
my 2p worth
Mike
- jason@bwchiptune
- Contact:
[quote=""Buster""] Only the dealer could fix it due to coding and the bill was £3000 and that was with discount.[/quote]
we are linked up to independents across the uk that can code as the dealer and more if anyone ever needed it:)
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
Crikey 13 posts from jason within less than 24hrs.............maybe too much Pro Plus
I reckon his missus kicked him out of bed!
Hi All,
Finally sorted out DSC inactive issue. As Buster advised earlier in the thread it was found to be an issue with the actuator on the transfer case. A local indy dismantled the actuator and found a plastic gearing mangled. A new actuator was sourced from Germany and fitted today. All ok at present cost was £500 + Vat + £100 labour. Would have been more if it was an automatic gearbox. Thanks for you responces always helps when trying to diagnose.
Kind regards Jt
Kind regards Jt
Thanks for letting us know the outcome aswell
....all info is usefull
