MOT Failure :(....Now Passed :)
x555
Post by x555 » Tue Sep 27, 2011 7:46 pm
Well i was sort of expecting this time with a few rattles and knocks here and there.
I thought that some bushings would be suspect to failure as we have developed a 'wheel wobble' when braking down from higher speeds and also the rear clunk when pulling away, which i thought was the rear trailing arm bush....and still may be :roll:
Stuff i should have replaced earlier i suppose.... time, money and all that :roll:
Here's what the MOT flagged up...
This does seem spot on aswell as the fronts would create the 'wheel wobble' under braking and the rear one would explain the slightly more tyre wear to the rear O/S tyre that i noticed earlier tonight under inspection :evil:
My question to you guys/gals is have any of you used after market parts at cheaper cost...any recomendations and if so how have they been. I have used non oem parts before and been quite happy with the results of some but i am also aware of you generaly get what you have paid for ;)
That and ive just checked with real oem and the original parts from bm are £192 each for the front wishbone/control arms :o :o :o :headbang:
dirtymonkey29
MOT Failure :(
Post by dirtymonkey29 » Tue Sep 27, 2011 8:16 pm
I usually use lemforder parts from eurocarparts. As far as I'm aware there oem without the BMW stamp.
535dboy
Re: MOT Failure :(
Post by 535dboy » Tue Sep 27, 2011 8:56 pm
Ouch, bad luck!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
4.8isDriver
Re: MOT Failure :(
Post by 4.8isDriver » Tue Sep 27, 2011 8:57 pm
hope you get things sorted soon!
Current:
Audi A5 Cab 3.0TDI Quattro
Previous:
E53 4.8is Le Mans Blue - ReMapped by Jason@BW and K&N
C5 RS6 Avant MTM Mugello Blue
VW Toerag V10 TDI
Subaru Impreza WRX PPP ver 8
Sanj
Re: MOT Failure :(
Post by Sanj » Tue Sep 27, 2011 9:03 pm
[quote=""535dboy""]Ouch, bad luck![/quote]
Uncalled for fella - can see what you're doing.... :ycard:
535dboy
Re: MOT Failure :(
Post by 535dboy » Tue Sep 27, 2011 9:06 pm
[quote=""Sanj""][quote=""535dboy""]Ouch, bad luck![/quote]
Uncalled for fella - can see what you're doing.... :ycard:[/quote]
I don't think you do
He will know
Currently :
2012 Audi RS4 (B8)
Previously :
Sanj
Re: MOT Failure :(
Post by Sanj » Tue Sep 27, 2011 9:12 pm
Can't let this one go can you.... shame.
535dboy
Re: MOT Failure :(
Post by 535dboy » Tue Sep 27, 2011 9:17 pm
[quote=""Sanj""]Can't let this one go can you.... shame.[/quote]
Don't understand what you are going on about.
We have spoken and all clear. Check with Mitch direct if you want.
Ouch = expense
Bad luck = it has happened at all
Think the shame is on you, fella, for jumping to the wrong conclusion!
Currently :
2012 Audi RS4 (B8)
Previously :
Sanj
Re: MOT Failure :(
Post by Sanj » Tue Sep 27, 2011 9:19 pm
[quote=""535dboy""]Think the shame is on you, fella, for jumping to the wrong conclusion![/quote]
Yeap, always two sides to a story :thumbsup:
Oh and primarily - my apologies to BOTH of you if I have jumped to conclusions.
But I will wait for the other side...
535dboy
Re: MOT Failure :(
Post by 535dboy » Tue Sep 27, 2011 9:22 pm
[quote=""Sanj""][quote=""535dboy""]Think the shame is on you, fella, for jumping to the wrong conclusion![/quote]
But I will wait for the other side...[/quote]
Let you off, just this once :poke:
Currently :
2012 Audi RS4 (B8)
Previously :
pvr
Re: MOT Failure :(
Post by pvr » Tue Sep 27, 2011 9:27 pm
And peace 8-)
Done the Polo MOT today - £39 at the VW dealer, good for another year. Not bad for a 2001 car.
535dboy
Re: MOT Failure :(
Post by 535dboy » Tue Sep 27, 2011 9:32 pm
[quote=""pvr""]And peace 8-)
Done the Polo MOT today - £39 at the VW dealer, good for another year. Not bad for a 2001 car.[/quote]
You've doubled the value of the car now then! :D
Currently :
2012 Audi RS4 (B8)
Previously :
Pewters
MOT Failure :(
Post by Pewters » Tue Sep 27, 2011 9:49 pm
I'm sure you will get those massive mitts under the car and get it sorted mush .......always a bummer when they fail though !!!
Sanj
Re: MOT Failure :(
Post by Sanj » Tue Sep 27, 2011 10:16 pm
[quote=""pvr""]Done the Polo MOT today - £39 at the VW dealer[/quote]
RIP OFF!!! £35 for mine! Then the brake fluid change, rear pads, front pads, pollen filter.........
Pewters
MOT Failure :(
Post by Pewters » Tue Sep 27, 2011 10:49 pm
[quote=""Sanj""][quote=""pvr""]Done the Polo MOT today - £39 at the VW dealer[/quote]
RIP OFF!!! £35 for mine! Then the brake fluid change, rear pads, front pads, pollen filter.........[/quote]
Don't tell me you need front pads again !!!! Bet you have only done 4k since you last changed them !!
