Page 1 of 2
Dull brake light at one side
Posted: Mon Sep 19, 2011 3:09 pm
by Pradaman
As per title my passenger side brake light is dull tried a new bulb but still the same any suggestions???
Posted: Mon Sep 19, 2011 4:05 pm
by Pewters
Did you check to see if the contacts had any sign of corrosion ?
Re: Dull brake light at one side
Posted: Mon Sep 19, 2011 6:58 pm
by AW8
Sounds daft but maybe trial swap the good one to dull side..........that way you know it's something other than bad bulb &/or bad replacement.
Posted: Mon Sep 19, 2011 7:07 pm
by Pewters
[quote=""AW8""]Sounds daft but maybe trial swap the good one to dull side..........that way you know it's something other than bad bulb &/or bad replacement.[/quote]
Good thinking .....not just a pretty face are you matey lol
Posted: Mon Sep 19, 2011 7:22 pm
by AW8
Mensa material me & a pretty face ...... NOT :)
Posted: Mon Sep 19, 2011 7:23 pm
by AW8
Just to add unless yours different to mine....... you can swap out the holders too.
Posted: Tue Sep 20, 2011 9:48 am
by strummer
likely to be water ingress into bulb holder
Posted: Tue Sep 20, 2011 11:19 am
by Pewters
The contacts do burn away on the holder .....that's what caused mine
Posted: Tue Sep 20, 2011 12:02 pm
by mizen296
I had same problem with mine kept in blowing lamps so I bought after Market led Ones much better look :)
Posted: Tue Sep 20, 2011 5:25 pm
by AW8
Not wishing to go off topic but offering word's of caution re aftermarket l.e.d. / led tail/stop lights.......some arent bright enough & might event result in a rear end moment if braking hard on a sunny day.
Posted: Tue Sep 20, 2011 5:29 pm
by Pradaman
Light unit had a bit of black where the contacts of the bulb holder sits cleaned it up
And managed to get the bulb holder to sit where it's getting a contact. Going to get the sparky at work to run a bit of solder on to it so it makes a good contact on a bigger area. Thanks for all the suggestions.
Posted: Tue Sep 20, 2011 6:12 pm
by pvr
Does your car live outside by the way?
Posted: Tue Sep 20, 2011 6:15 pm
by Pewters
[quote=""pvr""]Does your car live outside by the way?[/quote]
You make it sound like a dog LOL
Posted: Tue Sep 20, 2011 7:57 pm
by Sanj
[quote=""AW8""]Not wishing to go off topic but offering word's of caution re aftermarket l.e.d. / led tail/stop lights.......some arent bright enough & might event result in a rear end moment if braking hard on a sunny day.[/quote]
Alright, alright! I got the message - I sorted them! :poke:
Posted: Tue Sep 20, 2011 11:27 pm
by Rusty
[quote=""Sanj""]
Alright, alright! I got the message - I sorted them! :poke:[/quote]
Is that 'sorted' painted led's or 'sorted' cleaned the led's off again?
