Dull brake light at one side
Pradaman
As per title my passenger side brake light is dull tried a new bulb but still the same any suggestions???
- Pewters
Re: Dull brake light at one side
Sounds daft but maybe trial swap the good one to dull side..........that way you know it's something other than bad bulb &/or bad replacement.
- Pewters
[quote=""AW8""]Sounds daft but maybe trial swap the good one to dull side..........that way you know it's something other than bad bulb &/or bad replacement.[/quote]
Good thinking .....not just a pretty face are you matey lol
Mensa material me & a pretty face ...... NOT
Just to add unless yours different to mine....... you can swap out the holders too.
strummer
likely to be water ingress into bulb holder
- Pewters
mizen296
I had same problem with mine kept in blowing lamps so I bought after Market led Ones much better look
Not wishing to go off topic but offering word's of caution re aftermarket l.e.d. / led tail/stop lights.......some arent bright enough & might event result in a rear end moment if braking hard on a sunny day.
Pradaman
Light unit had a bit of black where the contacts of the bulb holder sits cleaned it up
And managed to get the bulb holder to sit where it's getting a contact. Going to get the sparky at work to run a bit of solder on to it so it makes a good contact on a bigger area. Thanks for all the suggestions.
- pvr
Does your car live outside by the way?
- Pewters
[quote=""pvr""]Does your car live outside by the way?[/quote]
You make it sound like a dog LOL
- Sanj
[quote=""AW8""]Not wishing to go off topic but offering word's of caution re aftermarket l.e.d. / led tail/stop lights.......some arent bright enough & might event result in a rear end moment if braking hard on a sunny day.[/quote]
Alright, alright! I got the message - I sorted them!
- Rusty
[quote=""Sanj""]
Is that 'sorted' painted led's or 'sorted' cleaned the led's off again?
Sent from my iPod device using Tapatalk
Runabout - E92 3 Series Coupe
