changing air filter E53 30d
How-To articles ONLY go here.
thedweeb
Post by thedweeb » Mon Aug 23, 2010 9:46 pm
CHANGING THE AIR FILTER ON A E53 3.0D
Changing the air filter on a 3.0d should be a 5 min job as it is on the petrol X5’s. However it’s not. I did mine today and taking my time it took me the best part of an hour from start to finish. Along the way I took a few photo’s that you may find helpful should you wish to take on the job yourself.
1.) Tools needed as follows – 13mm spanner. 13mm socket with wrench. 5mm Allen Key.
2.)Image
Remove the rubber trim that runs along the top of the bulkhead.
3.)Image
Undo the quick release screws around the pollen filter but not the two that take the actual filter out. You will then be able to remove the plastic scuttle.
4.)Image
Once you have removed the scuttle you will see to the left and right of the pollen filter a plastic scoop type thing. These need to be removed and this is done by just lifting them out.
5.)Image
Undo the two 13mm nuts using the 13mm spanner/socket.
6.)Image
With the two nuts removed you can slide out the pollen filter assembley. Be careful its heavy. The picture above shows the assembley removed,note you can now see the back of the engine.
7.)Image
To gain complete access to all of the bolts on the air filter housing you need to move out of the way one more piece of plastic. This is done by undoing the 13mm nut on the bottom of the wiper motor. Then the two 10mm bolts below that,then finally the plastic 10mm nut
The last picture shows the plastic trim moved out of the way,there is no need to remove it completly just prop it out of the way so that you can gain access to the air filter bolts at the back. Yes you got it all the work done so far is to get to the back two bolts on the filter housing.
8.)Image
Remove the plastic airfilter intake pipe. (photo taken before I started)
9.)Image
Again photo taken before i started but you then need to undo the five air filter housing bolts with a 5mm allen key. These bolts are captive so will not come all of the way out. The reason for removing the pollen filter assembley is to gain access to the two rear bolts. Once the bolts have been undone remove the oil filler cap. This will then allow you to remove the air filter housing.( tip – replace the oil filler cap as soon as you’ve the housing clear of the engine).
10.)Image
Housing removed ( filler cap back on) You can see the air filter lying north/south. To remove the filter just push it towards the bulkhead and lift out. When the filter has been rmoved you may need to hoover around the bottom half of the housing to remove a ny insects/bits.
11.)Image
The bits removed.
Obviously replace in reverse order.
Good luck......
The dweeb
X MAN
Re: changing air filter E53 30d
Post by X MAN » Tue Aug 24, 2010 12:45 am
Excellent write up, i did mine when the old site was down, like you say should take 5 mins but a
real PITA . Thanks for this how to, saves me doing the copy and paste thing through photobucket .
Did you do the oil breather filter at the same time ? Mines on a 05 and it did not have the modified oil breather filter.
05 X5 3.0d
Mods:H/s wheel.F/mirrors.Lumbar.Compass-remote r/v mirror.Rem ctrl.Bins holder.T90 Telestart.20"168's.Arches.Titan grills.Skid plate. P/O load floor.R/seat e/b/rest.R/blinds.H/rear seats.is r/bumper trim.chrome dials.car key mem.intravee.DSP.RV Cam.Dbl glazing.Ski bag,Rear blower
thedweeb
Post by thedweeb » Tue Aug 24, 2010 7:46 pm
Jesus didnt know there was one !!
bigshout
Post by bigshout » Tue Aug 24, 2010 10:59 pm
Wow, I would have thought it would have been as simple as my 4.4i. I replaced mine at the weekend, new filter from eurocar parts £4.50 and a 1 minute job, done!.
thedweeb
Post by thedweeb » Wed Aug 25, 2010 11:09 pm
Yea it should be a 2 minute job. Worth the effort tho as they often get ignored durring a service due to the work invovled.And once you've done it once its easy
Minda
Post by Minda » Thu Aug 26, 2010 7:37 am
Thats a lot to remove to get to the filter, is that just poor design or is there some reason for it to be so tucked away?
thedweeb
Post by thedweeb » Fri Aug 27, 2010 8:59 pm
I would say poor design.
pvr
Post by pvr » Fri Aug 27, 2010 9:28 pm
Dealer replaced mine, was not that expensive. About £35 in total.
Minda
Post by Minda » Fri Aug 27, 2010 10:00 pm
Thats not bad then :thumbsup:
pvr
Post by pvr » Fri Aug 27, 2010 10:39 pm
It was part of the extended second oil change I thing. Also involved the fuel filter change.
thedweeb
Post by thedweeb » Fri Aug 27, 2010 10:42 pm
[quote=""Minda""]Thats not bad then :thumbsup:[/quote]
Yea I was thinking that.But Enjoyed doing it myself tho.
pvr
Post by pvr » Sat Aug 28, 2010 9:37 am
I removed that whole guard a while back, can't remember why, but I do remember it being a fiddle to put back.
Post by X5Sport » Wed Nov 10, 2010 11:40 am
What year is your E53? Mine doesn't look like that under the bonnet, and the engine cover has a join at the rear so nothing other than the four screws to remove?
Mine is a 2005 MY and all that metalwork on the right of your engine is just not there on mine at all. The only thing I have to the right is a Webasto Thermo Top Z.
x555
Post by x555 » Wed Nov 10, 2010 1:32 pm
Great write up there dweeb :thumbsup: all these how too's are really handy to refer to when doing jobs on the car.It's part of what makes a great forum :D
thedweeb
Post by thedweeb » Wed Nov 10, 2010 11:40 pm
[quote=""X5Sport""]What year is your E53? Mine doesn't look like that under the bonnet, and the engine cover has a join at the rear so nothing other than the four screws to remove?
Mine is a 2005 MY and all that metalwork on the right of your engine is just not there on mine at all. The only thing I have to the right is a Webasto Thermo Top Z.[/quote]
Hi,
Its a pre-facelift 2002 model. You can understand by following the work that needed to be done why BMW decided to split the engine cover as on yours.
Dweeb
