				mud flaps- fitting?.
				Posted: Sat Aug 27, 2011 7:12 pm
				by wulliet
				Hi, anyone fitted mud flaps to there X5 and how easy is it to do?, and any help would help thanks...
				Re: mud flaps- fitting?.
				Posted: Sat Aug 27, 2011 8:43 pm
				by phiggystardust
				hi
i have fitted flaps to several car ive had and must say the x5 is the easiest, just need a small spanner 8mm i think to remove one of the inner arch fixings and a stubby screwdriver to fix the self tappers , an ordinary phillips driver would be ok if you remove the wheels , but with the stubby it fits between the tyre and the arch.the inner arch fixing then goes back in through the mudflap. think it was as easy as that but maybe someone will correct me . hope this helps
good luck
				Posted: Sat Aug 27, 2011 9:32 pm
				by wilkoturbo
				Will any fit the le mans ??
				Posted: Sat Aug 27, 2011 9:48 pm
				Not if you have wheel arch flares.  Mudflaps can only be fitted to non-flared arches.
				Posted: Sun Aug 28, 2011 5:12 pm
				by wulliet
				thanks for that phiggy will try when they come.
				Posted: Sun Aug 28, 2011 10:28 pm
				by phiggystardust
				no problem
need to know more let me know
				Posted: Thu Sep 01, 2011 5:20 pm
				by wulliet
				well got my mud flaps today and fitted same, quite easy as you said phiggy, did not have to take wheels off but would have been alot easier if i had, the old X is looking better and better....
				Posted: Mon Sep 05, 2011 5:58 pm
				Glad you got it all sorted
  They do at least keep the worst of the cr@p off the car
				Posted: Mon Sep 05, 2011 8:04 pm
				by phiggystardust
				tidy
				Posted: Sat Dec 15, 2012 1:20 pm
				by awj85
				I am considering fitting flaps to my x5.  Do u happens to have before and after pics?
