mud flaps- fitting?.
wulliet
Hi, anyone fitted mud flaps to there X5 and how easy is it to do?, and any help would help thanks...
bmw 5 series 3.0 1999, Z4 2,5 2004, X5 3.0D sport 2002.
phiggystardust
Re: mud flaps- fitting?.
hi
i have fitted flaps to several car ive had and must say the x5 is the easiest, just need a small spanner 8mm i think to remove one of the inner arch fixings and a stubby screwdriver to fix the self tappers , an ordinary phillips driver would be ok if you remove the wheels , but with the stubby it fits between the tyre and the arch.the inner arch fixing then goes back in through the mudflap. think it was as easy as that but maybe someone will correct me . hope this helps
good luck
good luck
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
- wilkoturbo
Not if you have wheel arch flares. Mudflaps can only be fitted to non-flared arches.
wulliet
thanks for that phiggy will try when they come.
phiggystardust
no problem
need to know more let me know
wulliet
well got my mud flaps today and fitted same, quite easy as you said phiggy, did not have to take wheels off but would have been alot easier if i had, the old X is looking better and better....
Glad you got it all sorted
They do at least keep the worst of the cr@p off the car
phiggystardust
tidy
awj85
I am considering fitting flaps to my x5. Do u happens to have before and after pics?
