Wheel Arch rivets
PhilT
Wheel Arch rivets
Post by PhilT » Sat Aug 27, 2011 5:31 pm
Hi everyone,
Can anyone tell me how to re-fit the black plastic rivets that secure the wheel arches? I'm guessing I need a rivet gun?
Guess I should have sussed this out before I removed them :oops:
Cheers for any advice.
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
Re: Wheel Arch rivets
Post by X5Sport » Sat Aug 27, 2011 7:33 pm
Not sure exactly which ones you're having trouble with, but does the centre not just push in again? I know on some types you remove the plastic centre, push the outer back into place and then plug the centre back into the middle to lock it in.
snipez999
Post by snipez999 » Sat Aug 27, 2011 8:03 pm
They are very easy to bugger up when removing unfortunately. A plastic rivet gun with rivets of various sizes is just shy of 20 quid on Fleabay. Or you can probably buy the odd rivet (no doubt for almost as much as a pack of 50 Ebay ones LOL) from your dealer.
Post by Raj » Sat Aug 27, 2011 10:24 pm
They are one shot deals unfortunately. Need to buy new ones.
Sanj
Post by Sanj » Sat Aug 27, 2011 11:11 pm
Yes - pop them through and then fit the new sleeve and the pin after that to lock them in place:
http://www.ebay.co.uk/sch/i.html?_nkw=b ... vot&_rdc=1
PhilT
Post by PhilT » Sun Aug 28, 2011 5:23 pm
Thanks for the responses everyone, and the link Sanj - I thought I'd read somewhere that they were re-usable and you just pushed the centre pin back in which is why I removed one :(
Better get myself on fleabay and order a gun & replacements
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
Pewters
Wheel Arch rivets
Post by Pewters » Tue Aug 30, 2011 8:18 am
The ones Sanj posted are the wrong ones
Post by Raj » Tue Aug 30, 2011 10:20 am
The ones where you push the pin through aren't correct. The ones for the arches are plastic rivets. You push the plastic rivet through and have to then pull the pin outwards to expand the backing to hold it in place. So once you push the pin through on the old rivet it's done with.
Pewters
Wheel Arch rivets
Post by Pewters » Tue Aug 30, 2011 11:18 am
Have a look at my thread in "how to" on Le Mans arch fitting thread and all will be clear.
Sanj
Post by Sanj » Tue Aug 30, 2011 3:50 pm
Pewters
Wheel Arch rivets
Post by Pewters » Tue Aug 30, 2011 9:29 pm
Nope !!! They are mudflap ones
Check my thread Sanj
