wheel spacers
wheel spacers
im after a pair of 20-30mm wheel spacers to fit x5 e53 also the long wheel bolts must be cheap as its for a trial run with 22s
current: 2016 Vw Crafter
Re: wheel spacers
Hiya buddy.
Give me till Wednesday as I may have a spare set of 20mm Eibach Spacers you can borrow to see if they fit ok. If you're happy then pay for them (can't say fairer).
Don't require longer bolts either as they are Eibach's bolt on types. Basically they come with bolts to bolt the spacer to the hub then bolt the wheel as per normal to the spacer. Far better and safer.
Re: wheel spacers
that sounds great, dont mind buying them bt I arnt 100% sure what size I need and buying and selling different sizes seems daft. If they work I can paypal u instantly if nt post em back to u. Is urs the v.nice 4.8is? If so have u had 4 wheel alignment done on 22s to sort rear camber? Thanks
Re: wheel spacers
Hi Raj .
If they are not req'd I may well be intrested as I am also after some .
Please let me know the outcome .
Cheers .
Paul .
Cheers .
Paul .
Re: wheel spacers
The 4.8is certainly is mine...cheers.
Let me try and get them back off my mate on Tuesday and will keep you posted.
I did have a 4 wheel alignment done but there is only so much in it from factory.
