Oil removal from the drive
baldguy
Post by baldguy » Wed Aug 10, 2011 1:12 pm
In a few days I will have my E53 back after the repair of a gearbox oil leak... As my drive now looks like a dot to dot pattern, whats the best cleaner to use? I plan on brushing it on and jet washing off...
Any info most grateful..
Cheers Greg
2006 Legacy 3.0R Spec B Wagon
2005 911 C4s Cab (Weekend toy)
millerman1ac
Re: Oil removal from the drive
Post by millerman1ac » Wed Aug 10, 2011 1:28 pm
also interested in this...
my work banger had a leaky sump, i have more than a few dots lol!!
2004 4.4 Sport Black with Black
1998 Suzuki TL1000R, power commander, ART cans, K & N, TRE
Post by X5Sport » Thu Aug 11, 2011 2:27 pm
What's the drive constructed from?
If tarmac you have to be careful not to dissolve it when using something like Jizer - which has a solvent in it. Some form of detergent is probably your only choice. Hot water/steam is out as it will melt the binder.
With concrete a pressure washer with a good strong detergent, or possibly engine cleaner, sometimes works if the oil is not too deeply ingrained, but bear in mind where the run-off goes. You could always scrub the immediate area and the hose it off. See below for another possible.
Block/Brick paving is a nightmare to clean. Not come across anything that really works without a lot of effort and very hot water. I have seen people try wallpaper steam strippers with absorbent pads on to soak up the oils. No idea how effective that might be though.
pvr
Post by pvr » Thu Aug 11, 2011 3:29 pm
I have the Halfords drive cleaner for when I have visiters with leaky cars. I have a lot of black paving and it works well for that (with a brush )
Post by sapphireblack » Thu Aug 11, 2011 4:35 pm
So called 'forecourt cleaner' as used by filling stations to clean up spillages works extremely well. It's a detergent (with a nice whiff) i imagine any decent motor factors could supply it (5ltr iirc) which rules out halfrauds i imagine.
An [url=examplehttp://www.dynamic-chemicals.co.uk/product.asp ... 1&P_ID=795]examplehttp://www.dynamic-chemicals.co. ... 1&P_ID=795[/url]
millerman1ac
Post by millerman1ac » Fri Aug 12, 2011 8:57 am
my drive is tar, looks real bad quite alot of oil went down i was parking ontop of a bit of wood but gave up after a while..
i have the sump repaired now so hopefully can make the mess look a wee bit better, it's very tricky parking on the exact same spot you know lol!!
