screen wash delay
Smeeagain
screen wash delay
Post by Smeeagain » Tue Jul 26, 2011 11:06 pm
Hi - hope someone can help me get to the bottom of this problem on my 2004 3.0d Sport E53 X5.
When I press the screen wash button sometime the liquid hits the windscreen instantly and sometime it takes up to seven or eight seconds. I cant see any blockages and I've taken the filters out of the reservoir and cleaned them but its made no difference. Sometime it happens sometimes it doesn't. It only seems to happen on the front screen not the rear
Anyone got any ideas?
Smee
scooby1doo1
Re: screen wash delay
Post by scooby1doo1 » Wed Jul 27, 2011 5:22 am
Depending on time of day or your lights on does it wash the headlights first, then the screen hence the delay.
Turks
Contact:
Post by Turks » Wed Jul 27, 2011 9:14 am
If it is not what has been said by smeeagain, it could be that the pump is letting screenwash back into the bottle or leak. If this is happening then it will take a few seconds to recharge the lines with screenwash before anything comes out of the Jets.
Turks.
Present:
Past:
Smeeagain
Post by Smeeagain » Wed Jul 27, 2011 1:23 pm
its not a headlamp associated delay - it happens during the day. It does feel like the lines are being recharged - will continue to hunt further
Smee
Turks
Contact:
Post by Turks » Thu Jul 28, 2011 6:31 am
Try to check all of the joints along the lines first, as well as where they meet the pump. If you have a couple of spare mates, then dry the lines, get them to put their fingers over the jets while you try to squirt them. The back pressure might reveal where the screenwash maybe escaping.
Turks.
Present:
Past:
Smeeagain
Post by Smeeagain » Thu Jul 28, 2011 11:05 am
OK, here is a further symptom - a bit weird in my opinion but hopefully it will tell someone something as its quite definitive
With the car parked and the ignition only on, the screenwash works first time every time, perfectly. The delay in delivering the water ONLY happens when the engine is running. I know this as I've spent he last half hour on the driving way testing
it and it was always working. Out of curiosity I switch the engine on and now I get the delay. Switch the engine off and all is fine?
Some kind of electrical drain perhaps pulling power away from the pumps? Dunno
Smee
