Post
by Sanj » Wed Jul 27, 2011 4:46 pm
You have to take the airbag off first (spring loaded clips behind the horizontal spokes, use a screwdriver) - then 3 screws iirc at the back of the steering wheel and the centre part comes off.
Be careful if you take the airbag out - best to remove the fuse or battery terminal. And DON'T switch the ignition to poistion 1 or 2 as the light will then come on and only possible to reset at dealer/indy (unless your scanner can do it).
