OK...So i have now completed the change over of my 2 x front and 2 x rear sparkers. I have also disconnected the front tweeters in the dash as these were affecting the quality of the new speakers i had brought when i was trying to set them all up.......
I'm going to post some pictures on here because people were really helpful in asking the questions i had when i decided to change the speakers.....so Thanks!
1st: I read some posts on here, watched some youtube videos, looked at bevariumsound website and basically all the info is there!
I also brought some interior trim removal tools from Ebay, really cheap think i paid £6 for them and they were priceless! Used them loads of times to remove the panels, switches etc and didn't scratch a single thing!!
I brought the following speaker from Peter Doige in Great Yarmouth:
Focal K2 Power 165KR 160w for the fronts
Hertz Coax ECX 165 140w for the rear
The next few steps were reasonably easy.....
1 Remove the interior trim silver panels, remove the airbag badge, remove the window switches
2 Remove the 4 x screws
3 remove the bottom interior light
4 Remove the door panel - can be a real pain but abit of wriggling and lifting over the central door fitting and it soon comes off. Be carfeul to not pull the panel away before you release the door catch and the small light which lights up the interior door handle.
Then........(They are all the same!)
Remove the speaker housing.
Remove the speaker - takes abit of bashing and persuasion with a screw driver but you'll get there!
I then had to trim the housing to enable my speakers to fit....
I also had to drill a hole in the door panel to allow 2 x screws to go in a hold the speaker cross-over in place....all very straight forward!
Just got to nip out!! ....Finish this later!!
