Took the X out for a drive last night………Parked up with the engine running whilst the other half used the cash point……….Pulled away and felt a jolt.
The Self level susp. Inact warning and the tyre pressure warning light came on………….Straight a way the handling from the front was extremely bouncy…….Kept to a low speed all the way home but when turning a corner you could hear the tyre rubbing the wheel arch.
I know that the air suspension can be problematic on the X5 but look at these photos
Both the front off side and near side wings are virtually sitting on the tyre, the rear tyres are about 4 inches below the wheel arch. There is also now no LED indication on the suspension level switch.
I spent some time on Outpost searching for similar problems and found quite a bit. The general consensus was it could be a fuse, levelling sensors, air bags or control unit………Virtually every or any component then……
As I have extended my AUC warranty (albeit with a £100 excess) the car goes in tomorrow to my local BMW dealer. Now I will see how good this warranty is……..
Will post update tomorrow………
