A few weeks ago I stopped the X5 and the 'Check Engine OIl Level' warning ponged up.
Checked the levels and it was just above min, so poured in half a litre.
Yesterday it ponged up again and sure enough the level is just above minimum.
The car hasn't dropped any oil on my drive and it doesn't appear to be burning oil as I've followed it plenty of times on my motorcycle.
Maybe it's dripping into the sump guard and I just can't see it.
Any suggestions?
Oil consumption or unseen leak?
Current Rides:
2007 Black X5 E70 3.0D SE - 7 Seater, Dynamic & Media Packs
1975 MGB Roadster with Rover SD1 V8 conversion, Offenhauser Manifold & Holley Carb - Straight lines only.
2005 Honda Hornet with Akrapovich zorst & other odds n sods.
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Previous Ride:
Re: Oil consumption or unseen leak?
I think your only option is to drop the under cover and take a look for leaks or residue leaks?
2009 35d, Space Grey with Chateau leather, still below 40k miles.
It would be helpful if you had your model etc in your signature...
When was your last service or the last time you checked your engine oil level previous to the error message?
Turks.
Turks.
Present:
Past:
Past:
If it's a Diesel, then you can expect about 1/2 litre every 1,000 miles or so. BMW state that the engine is 'expected' to use this much and it's completely normal. No idea what the normal consumption is on the Petrol models though. It always struck me as quite a lot to use considering no other current car I have owned with a diesel powerplant has used that much. Our E53 certainly uses around that amount and has since new. The E46 with the same engine a little less than the E53 and the X6 nothing at all.
3 litre petrol - saw it in another post...
Sorry peeps...
It's a 2003 3.0i Sport with 69,000 on the clock now. Bought it fully serviced with 65,000 miles on it 5 months ago.
Current Rides:
Previous Ride:
Previous Ride:
[quote=""sapphireblack""]I think your only option is to drop the under cover and take a look for leaks or residue leaks?[/quote]
Sounds like a plan. Is it easy to drop? Any watch-outs?
Current Rides:
Previous Ride:
Previous Ride:
