coolant level
Posted: Fri May 20, 2011 5:41 pm
by baner16
hi all
had a small leak on the expansion tank so yesterday change it
did not lose much water in the change over and everything seemed to go ok
now i am getting error check coolant level
level seems fine car does not overheat and heater works fine
any ideas you brainy lot
cheers carl
Re: coolant level
Posted: Fri May 20, 2011 6:57 pm
Have you checked the coolant level with the engine cold? It has to be cold as the level will drop. You may also have a bit of air in the system, and/or check the connectors are all plugged in? It's the only thing I can think of if the coolant levels are correct.
Re: coolant level
Posted: Fri May 20, 2011 8:21 pm
by baner16
checked the level today and its fine
red float up to the top of the cap
no leaks as far as i can see
read some where about a self bleed you can do
tried that and it seemed fine
dont no what else to do
Re: coolant level
Posted: Fri May 20, 2011 9:08 pm
by Raj
May be the level sensor itself or just the connection.
Re: coolant level
Posted: Sun Jun 19, 2011 12:13 pm
by baner16
help really bugging me now
still having it say check coolant level
today i have replaced the coolant level sensor and im am still getting message on the screen
no leaks no overheating heater working fine
does anybody have any more ideas
cheers carl
