hi all
had a small leak on the expansion tank so yesterday change it
did not lose much water in the change over and everything seemed to go ok
now i am getting error check coolant level
level seems fine car does not overheat and heater works fine
any ideas you brainy lot
cheers carl
coolant level
- baner16
coolant level
E71 30d
Re: coolant level
Have you checked the coolant level with the engine cold? It has to be cold as the level will drop. You may also have a bit of air in the system, and/or check the connectors are all plugged in? It's the only thing I can think of if the coolant levels are correct.
Never anthropomorphise computers. They hate that.- baner16
Re: coolant level
checked the level today and its fine
red float up to the top of the cap
no leaks as far as i can see
read some where about a self bleed you can do
tried that and it seemed fine
dont no what else to do
E71 30d
- baner16
Re: coolant level
help really bugging me now
still having it say check coolant level
today i have replaced the coolant level sensor and im am still getting message on the screen
no leaks no overheating heater working fine
does anybody have any more ideas
cheers carl
cheers carl
E71 30d
