Treated the x to an oil change
x555
Post by x555 » Wed May 18, 2011 8:03 am
I serviced the x last night with an oil and filter change.Hadn't done it before so was a little aprehensive but after taking half the engine apart to replace the manifold previously aswell as other jobs i was pretty confident.....it was just a case of fear of the unkown i suppose :lol:
Anyway it was a simple task and saved a few spondooleys in the process :D
It was a messy oily job but i did manage to take a few pics which i will add after.
Re: treted the x to an oil change
Post by Raj » Wed May 18, 2011 8:31 am
Nothing like doing it yourself.
wilkoturbo
Post by wilkoturbo » Wed May 18, 2011 8:59 am
It's a good feeling when done yourself :)
bmw x5 le mans blue
ITBarbie
Re: Treated the x to an oil change
Post by ITBarbie » Wed May 18, 2011 11:36 am
Well done you! You are brave as the nearest I have got to oil is in the kitchen :-)
2004 Sapphire Black 3.0d SE
MODS
Post by X5Sport » Wed May 18, 2011 12:07 pm
Did you do it from underneath, or suck it out from above?
lezmtaylor
Post by lezmtaylor » Wed May 18, 2011 12:28 pm
I recently changed the oil and filter on my 4.4 v8, not as easy as I thought it would be.
1. Could not shift the sump drain plug, so bought a dipstick suck thro' bit of kit (£45) , magic tool got nearly all the oil out of sump.
2. Then could not shift the oil filter nut (it is a biggie -36mm) went and bought a special low profile socket off ebay. worked a treat.
V8 owners beware and get the tools first.
Lez
x555
Post by x555 » Wed May 18, 2011 6:50 pm
[quote=""X5Sport""]Did you do it from underneath, or suck it out from above?[/quote]
This pic may answer your question ;) Image
Mrs x555 is still lookng for her washing bowl :lol:
x555
Post by x555 » Wed May 18, 2011 6:55 pm
[quote=""lezmtaylor""]I recently changed the oil and filter on my 4.4 v8, not as easy as I thought it would be.
Lez[/quote]
Just to note that the e53 3.0ld is a smaller socket for the oil filter cover 32mm iirc (i will check again to make sure of the size)
I know this as i bought the same socket of ebay like Lez and it didn't fit :headbang: after being told it would :roll:
x555
Post by x555 » Wed May 18, 2011 7:07 pm
Pics as promised earlier.......
New parts ready to be fitted including new crush washer for sump plug bolt and new rubber o ring for the oil filter housing...
catchment bowl at the ready
you gotta be quick with that bowl :rofl:
32mm socket (i think iirc) to undo the oil filter housing
old oil filter removed
new one in place
I re fitted the sump plug bolt and new oil filter and then added about 6 litres of 5w30 longlife oil turned the engine over to circulate the oil and then topped up accordingly until i was right on the dipstick :D
I used aprox 7.5 litres of oil.
Sanj
Post by Sanj » Wed May 18, 2011 7:27 pm
Nice one buddy.
She'd kill me if I used any of her bowls!!!
chubbs
Post by chubbs » Sun Mar 06, 2016 4:52 pm
[quote="x555"]
[quote="lezmtaylor"]I recently changed the oil and filter on my 4.4 v8, not as easy as I thought it would be.
Lez[/quote]
I know this as i bought the same socket of ebay like Lez and it didn't fit  <!-- s:headbang: -->:headbang:<!-- s:headbang: -->  after being told it would <!-- s:roll: -->:roll:<!-- s:roll: -->
Just popped out and checked the oil filter nut on my 2004 3.0i petrol engine and it's 36mm, so it's worth measuring before you buy a socket.
