Fuel trim
- henrym3
Fuel trim
Multiplicative is of the scale as is LTFT so the suggestions are big vacuum leak, low fuel pressure with possible ccv diaphragm split, o2 pre cat sensors or MAF. Odd thing is that it is running well, no stalling, hesitation or any other issues. I was just playing about with the diagnostics cos I was bored. So started with a smoke test. Had to abandoned that as there was so much smoke pouring out from the inlet pipe where it is jubilee clipped to the throttle body, throttle body to inlet manifold and the bit the throttle body connects to has another seal. Ordered the bits from BMW. Got them fitted and the smoke machine back on and one of the pipes from the LPG injector to inlet manifold is leaking. Fixed that and got the fuel pressure tester out. 2 bar pressure. Changed the filter, what a bloody difficult job just getting to the filter. Run fuel pump from diagnostics and get 2 bar. So now got a fuel pump on order. Oh, the new heater valves I fitted in January are letting hot air bleed through when a/c is on, the bottom couple of vents allow the hot air in. Changed them, luckily they were 10 year warranty so should get my money back. Hopefully when the pump comes that will cure the pre cat o2 sensors permanently reading 1.04 and that will be all the problems fixed that I didn’t even know I had. It’s been a great week.
Fuel trim
Was the heater valve a cheap ebay special ? , I've ordered a bosch one for my e70 of Autodoc as I was wary of the cheap ones were just too cheap on ebay circ 25 quid.
2 bar isn't enough should be at least 3 id think for older petrol cars , at least you found a few leaks you didn't know you had
on a different note I found the rear 30 cm of my passat sills was detachable by hand
aka rotten to hell , spend 3 days under it welding so far ,still a bit to go ,id swap your issues for mine as welding inner sills under a car with about 30cm headroom in 20c heat ain't no fun
- henrym3
Fuel trim
Well I payed £39.99 and it had a 10 year guarantee. So at the time I thought they must be confident in the product. When removed I plugged it back in and operated the temperature controls and you could see that the brass cones weren’t fully seating and would allowing coolant to bleed through. They have finally agreed this morning to replace the item. I’ve taken another one rather than the money as I only payed £24 for the one now fitted. Which probably guarantees that the £24 one will work for ever.
I h’ave decided to replace just the fuel pump rather than the whole cradle as they now seem to sell them separately, obviously I didn’t think it through enough as I can’t fit it as I haven’t got a jubilee clip small enough to secure the pipe to the pump, I’ll go and get one after I’ve watched f1 qualifying. If this pump doesn’t get me 3.5 bar I’ll be stumped.
You’re welcome to your welding task, I’ve had to give it up as I’ve got a bit of hand shake these days, something for you to look forward to as you age. I suppose if you wanted something welded in a zig zag pattern then I’m your man.
Fuel trim
I seen a few things guaranteed on ebay and have had replacements sent out before of cheap bits and although replaced it lasted no time either and in the end had to buy a more expensive one. My welding ain't anything to write home about either but it gets the job done , it doesn't need grinding much as its only an mot quality repair and is hidden by the skirt and certainly isn't worth spending much time on as its probably only got 1 more mot left now.
- henrym3
Fuel trim
Now completely confused.New filter, new pump. Pressure measured at pump outlet 8 bar. Pressure measured at filter outlet 3.2 bar. Pressure measured at fuel rail 2.5 bar. I understand the excess pressure from pump is returned to tank from the prv in the filter so the prv is out by 1 bar. How is it loosing 1 bar between filter and the rail. It holds 2 bar overnight so surely that suggests the injectors aren’t leaking.
I checked with BMW today on the price of a filter. It’s special order and takes 7 working days and costs £142. So that’s not happening. Do I really need to remove the rail and injectors to check for leaks.
- henrym3
Fuel trim
No the pressure regulator is in the filter. Whatever pressure comes out of the filter outlet should be felt in the rail. I suppose I just don’t want to admit that one or more of the injectors are leaking. Complete pita to remove the rail and injectors because the LPG injectors and pipe work have to come off first.
- henrym3
Fuel trim
So done some tests on the fuel system and reading as well. The 4.6tu engine is supposed to run at 3.5 bar at all times ie idle or wot. The "vacuum " line isn’t a vacuum line at all it is a return to engine fuel line should the diaphragm in the FPR rip/tear and the line goes to the intake tube before the throttle body. So the fuel is dumped into the intake tube then sucked into the inlet manifold. So with ignition on and switching the fuel pump on with diagnostics I pinched the return line and the pressure jumped to over 3.5 bar at this point I switched the pump off and held the pinch. The pressure dropped 0.4 bar in 2 hours, well within spec. This also shows there is no leaks in the system or injectors. Can’t decide whether to get another filter or an adjustable FPR and just add it to the return line. Decisions Decisions.
