Driver side knocking
pcdee
Post by pcdee » Sat Jul 04, 2026 2:40 pm
Hello all!!
Front Suspension Components Already Replaced:
​Thrust Arms / Tension Struts (The large, forward-facing lower control arms with the fluid-filled bushings)
​Anti-Roll Bar D-Bushes
​Anti-Roll Bar Drop Links (The vertical rods connecting the anti-roll bar to the struts)
​Strut Top Mounts & Bearings (The assemblies at the very top of the shock absorbers under the bonnet)
Track Rod Ends
​The Issue:
Persistent front-end knock/clonk when driving over bumps and uneven road surfaces.
​Diagnostic Notes to Include:
​There is absolutely zero noise, play, or movement when the car is jacked up and the wheel is shaken at the 12/6 or 9/3 positions.
​The noise only happens when the suspension is fully loaded with the 2.5-ton weight of the car on the ground.
Front end knock felt directly through the footwell floor over bumps. Completely disappears under braking.
I'm out of ideas :?
Greydog
Post by Greydog » Sun Jul 05, 2026 7:20 am
I had a knock when I brought the car and went through a similar process. Not much left for you to change? just the upper wish bones and lower control arms. Upper wish bones are a fiddle and better with an assistant due to the nuts being inside the engine bay and the bolts under the wing. I set mine parallel to the ground for tightening I couldn't get a torque wrench in there as the strut was in the way so just did them up really tight with an extended ring spanner (been OK for 3 years) then tighten the spherical joint The lower control arms have different length inner and outer bolts mine were around the wrong way and very rusted so I brought new bolts din't change the arms just the bolts and re-torqued them no more knock
pcdee
Post by pcdee » Sun Jul 05, 2026 9:13 am
Since the clonk is identical before and after the overhaul, it's either those upper wishbones you mentioned or internal play in the steering rack housing itself. I'm going to pry-test the upper arms next to see if they have any movement!"
pcdee
Post by pcdee » Tue Jul 07, 2026 11:35 am
Upper arms are fine, next will and final piece to check is the steering thrust nut.
Greydog
Post by Greydog » Wed Jul 08, 2026 8:23 am
If you can feel it through the floor my bet would be the Lower control arms as said with my E70 the lower arms had been changed but the inner and outer bolts were in the wrong place the inner bolt could not be tightened (I tried) the inner bolt was so tight I had trouble undoing it !!
The inner bolt should be M14 x 100mm the outer M14 x 105mm whoever changed the lower control arms had put the bolts back in the wrong place the inner arm the nut was tight against the thread end bolt shoulder and while tight allowed the clonk and shoulder wear on the front tyres.
I brought new bolts and nuts fitted and torqued in the correct place no more clonk and no more tyre wear on outer shoulders
