2010 E70 X5 - Front of car oil leak
Sm[]key
Post by Sm[]key » Sun Mar 01, 2026 3:07 pm
Been holding this one off since the new year due to poor weather at weekends for a couple of month, had no excuse today to investigate the bad oil leak which has had the car parked up. :cry:
Looks to be coming from the crankshaft pulley. :thumbsdown:
Has anyone come across this before?
Post by Leslie » Sun Mar 01, 2026 5:35 pm
With the engine in this is going to be a bit tricky for clearance but yes looks like crank seal :thumbsup: getting something big enough diameter to tap it in should be the only issue after you get the pulley off which i think is a 4 bolt pulley , you changed that before so you know how to get it off.
Sm[]key
Post by Sm[]key » Sun Mar 01, 2026 6:20 pm
I'm guessing when the old pulley gave up its mis-balance knackered up the crankshaft seal.
Parts ordered, job for next weekend if they arrive in time. :thumbsup:
Post by Leslie » Sun Mar 01, 2026 10:44 pm
Just wear and tear at that miles it did well :thumbsup:
Sm[]key
Post by Sm[]key » Sat Mar 14, 2026 7:20 pm
Attempted today, tried the two self tapping screws trick into seal to pull out. Wouldn't budge!
Ordered an overnight seal puller, Amazon job so not holding up much hope!
Sm[]key
Post by Sm[]key » Sun Mar 15, 2026 5:40 pm
My faith in Amazon tools was warranted! Snapped one of the puller arms within a couple of minutes of use. The seal didn't move either.....
Need something more heavy duty, and most likely more expensive to buy! :headbang:
Post by Leslie » Sun Mar 15, 2026 6:44 pm
Need some bigger screws :rofl: unfortunately the crank is in the way so using some more effective pullers won't work .
This vid they had similar trouble , I wonder would tapping it on in at one point tilt it and make it pop out at the other side to get a grip on and make removal easier
Sm[]key
Post by Sm[]key » Fri Mar 20, 2026 8:26 pm
Got another puller, https://www.amazon.co.uk/Lisle-58430-Sh ... th=1&psc=1. Tried it this afternoon!
Snapped the end off within 10 seconds of using it..... :thumbsdown:
Plan C --> Thank god for same day Amazon prime, got this one 30 mins ago: https://www.amazon.co.uk/dp/B09339K3F1? ... asin_title
Slowly managed to ease it out took about 10 minutes though and a lot of perserverance. :thumbsup:
Post by X5Sport » Fri Mar 20, 2026 9:04 pm
The OEM puller is tubular seems to screw into the seal and then a bolt pushes against the crankshaft and pulls it out.
Another series of special tools are then used to align and push the seal into place. There is a warning though (applies to the OEM seal if you are using one - no idea for after market). Do not touch the surface of the seal lip at all. It is coated with Teflon and must not be contaminated. If it is, even slightly, then do not use it. It won’t seal properly (or won’t for very long). The end of the crankshaft must also be spotlessly clean with no residue. A fine Scotbrite can be used to clean the surface. Emery Cloth is a no no!
Post by Leslie » Fri Mar 20, 2026 9:38 pm
Glad you got it sorted :thumbsup:
Sm[]key
Post by Sm[]key » Fri Mar 20, 2026 11:12 pm
The seal itself has disintegrated, hence the two self tapping screw trick didn't work. Once I put a kink in the metal frame it slowly worked it way out. The seal I got was an OEM Vaico seal, I was advised to put it in with silicone spray. Is that a no no then?
Post by X5Sport » Sat Mar 21, 2026 9:05 am
It just says do not touch with fingers.
Sm[]key
Post by Sm[]key » Sat Mar 21, 2026 5:23 pm
Easier said than done, was a bugger to get in.
Not hopeful it will seal fully.
Engine out job really to do it properly.....
Post by X5Sport » Sat Mar 21, 2026 7:43 pm
The good book says you can do it with the engine in place. Needs a bit of tube the right size to tap it home - or BMWs special tool which cranks it in using one of the cranshaft holes to mount a pusher. The first tool bolts into one of the four holes and the second tool goes over the centred stud. The nut then winds on against the sleeve to push the bearing home.
Sm[]key
Post by Sm[]key » Sat Mar 21, 2026 8:53 pm
The inner seal folds over itself as interference fit, the seal comes with a plastic guide in the middle to help this transition onto the shaft.
Like I said easier said than done trying to line it up central then hold it there whilst pushing it in...... :headbang:
