Castrol EDGE 5W-40 Turbo Diesel (Titanium FST)
pcdee
Post by pcdee » Thu Nov 20, 2025 6:17 am
Morning
I'm having an oil change done and was recommended to use Castrol EDGE 5W-40 Turbo Diesel (Titanium FST) due to the high mileage.
They said it's thicker and will coat the engine better.
I said it's not LL04 and they said the 5W-40: This is the thickness your high-mileage engine needs to seal the rings and quiet the chain. It is ACEA C3: This guarantees it is safe for your DPF.
Any thoughts?
Post by X5Sport » Thu Nov 20, 2025 5:15 pm
If it’s not LL04 then you must change it every 10,000 miles. It sounds fine other than that. ACEA C3 is what LL04 is approved with. On a high mileage car it probably makes sense to do more frequent changes anyway. If it’s an N57 series engine then it’s a ‘MUST’ to avoid, or at least reduce, timing chain breakage risks
Post by Leslie » Thu Nov 20, 2025 5:28 pm
You don't need a different oil for hgh mileage , mine has 177k now( m57 x5sd ) and is using virtually no oil , if the chain is rattling you need to bite the bullet and get t sorted before it jumps or breaks and trashes your engine . The amount of n57 engined x5s for sale this last while with blown motors is huge , was just talking to my neighbour yesterday and his friend's 2015 one had to get a new crank recently due to it knocking its bearings out , a very common issue now . Imo if I had one id be changing the oil every 5k and / or get a warranty :D
Post by Alan Gunn » Fri Nov 21, 2025 4:55 am
Mine has just ticked over the 200k m57 e53 x5.
5w30 ll04 is what it has had all it's life and don't use a drop.
12 monthly oil changes or 7k for mine.
