Ios 26
Posted: Sat Sep 27, 2025 9:20 am
Had a new iPhone and was trying to re-enable the CarPlay on the M, that was a rather challenging job.
Even though the phone is found, and you can connect and pair using BT, it fails with the CarPlay part after you tell the phone to connect.
The way to fix that in my case was to drop the WiFi to the car after which it finally worked.
The only car with the issue so far, the others just worked.
