Hi folks
Once again my key fobs have dropped out and won’t lock or unlocked car so what I would like to know is with the key fob when you lock car and press lock again with in so many seconds you disarm internal sensors how do you do this when locking with the key ?? Thanks
Key fobs
Key fobs
Reading the Owners Manual makes no mention of being able to do this other than with the lock button on the remote key.
What’s causing the key fobs to drop? Charging issue? You can charge key fobs with one of those inductive charging pads or an electric toothbrush base (Braun / Oral B type) that also use inductive charging.
I use one of them for the E46 key….available from Amazon. Search for Apple iWatch charger. About £6.00 (Amazon won’t let me copy any item link today).
ssrfr03
Key fobs
Not to sure started playing last month when doing the brakes car was left for three weeks waiting for parts then once use car it’s started to work again then dropped out last week again
Cars been on a 3 hours run and the battery on charge for 2 days still not working on key fob car start fine every time ?
