2010 E70 X5 3.0d - Power Steering Heavy
Posted: Thu Jul 03, 2025 10:33 pm
				Had a right time with the old battle axe this week, knocking on 307K miles and still chugging on!
Noticed a heaviness in the power steering at very low speed at opposite locks at beginning of week, checked the fluid reservoir and notice it was just below minimum.
Topped it up the next day evening with CHF11S fluid, then drove to a nearby town for a run out, all seemed ok.
Had some scran and then drove back home after the sun had set, approx. 30 minute journey 15 minutes into the journey red battery light came on, then yellow 4x4, then yellow gearbox light, then yellow battery light! The dashboard was merrily pinging away faults!
I've got the BimmerLINK app and blue tooth OBD dongle, so ran the fault codes:
4BDA low pressure fuel control
4A17 Generator (Layer_GEN)
4A66 power management wiring system (Layer_PMBN)
5014 Supply Voltage
55C3 VGS four-wheel -drive system activated. No DXC setpoint default.
55CE CAN_MESSAGE_GETRIEBEDATEN, BA
5DCE - Uz supply voltage_terminal_15 error: slight under voltage; Voltage too low--- (DCS:DCS control unit under voltage)
5F2F - 5F2F - EGS error
6E22 - DME error
(There were more but have given up typing them out..)
Initially thought I had caused a short circuit due to bashing the rear reg plate lamps to turn back on before setting off previous to the faults.
I promptly turned off all electrical devices I could on the car, as I knew things like the gearbox needed power to run, I somehow managed to get home, put the car into reverse and then everything cut out. Tried to restart the engine and the battery was dead.
I disconnected the rear Reg plate lights and then did a battery test (all ok) and then recharged the battery overnight and run another battery test ok. I started the engine up the next morning turned the lights on and left it running for about 20 mins --> red battery light appear, turned car off and then it would not restart. Battery tester said it had 0% charge. Assumed I had a faulty battery or really bad short but no tell tail signs of melting wire insulation.
Obtained an new battery, reset all the fault codes, registered the new battery, and then drove 300 miles with no power problems, apart from the power steering still wasn't right, it was ok at speed on motorway but when slowed down has intermittent heavy steering.
I think this could be very dangerous and I may end up hitting something at low speeds when turning.
Any ideas what this could be? No steering faults are showing on BimmerLINK. Could it be a slipping belt?
Going to start investigating tomorrow morning.
5014 Supply Voltage
6E22 - DME error
 as there are no faults maybe jack up the front and if its hard to move the wheels lock to lock by hand with the engine off incase its a siezed topmount or steering joint ..
