				BMW x5e70 40d 2011 Kalashnikov in engine bay
				Posted: Mon Mar 03, 2025 5:10 am
				by isq000
				Morning folks
I would appreciate is someone could shed some light on this, tried to look online and didn't come across anything. Went for a long drive somewhere around 5 h to sea-side and back. Once returned home got this noise coming from what seam's to be engine bay once i switch the car off.No light's on dash, drives fine, no power loss.
https://youtube.com/shorts/3tclAaNa4uM?feature=share
				Posted: Mon Mar 03, 2025 5:57 pm
				Something’s not disengaging when you switch off and taking a moment to do so.  I couldn’t hear it with the engine running - which sounded normal.  I would have said some form of clutch such as the mechanical engine fan (not the electric one).  Whatever it is spins after engine off.
See if you can localise it.  The acoustic cover on the engine lifts off easily which well let you see more of the items connected to the drive belts.
				Posted: Mon Mar 03, 2025 8:46 pm
				by isq000
				I did take off the cover and the filter ect,the tick isnt mechanical but sounds more like electric tick if that makes any sense.with all the covers off ect sounds like top of the engine.I booked the car in local garage to have a look at just thought some have come across similar issue
				Posted: Thu Mar 06, 2025 1:04 am
				by isq000
				Update.
As weird as it sounds had the issue for 2 day's , on day 3 it just disappeared. Car is the same as it was before how about that
				Posted: Thu Mar 06, 2025 6:01 am
				by Alan Gunn
				Gremlins doing a stock take by the sound of it.
Show the garage that video.
				Posted: Thu Mar 06, 2025 7:57 am
				Finding intermittent issues is an absolute pain!  We’ve got a 20 year old E46 that keeps losing the near side mirror controls.  Nothing shows up on test.  It’s £650 to replace (at Indy prices) it so I want to be sure it needs replacing before I commit.  It was in yesterday and of course worked perfectly all day!
				Posted: Thu Mar 06, 2025 8:03 am
				by isq000
				Alan Gunn wrote: Thu Mar 06, 2025 6:01 am
Def. Will do ! I'll update on every step i take, might help someone in future.
				Posted: Thu Mar 06, 2025 12:22 pm
				by isq000
				Ok Update 1.
Wen to shop all around would say 20/ 30 min drive. On Idrive oil level came up as oil level too high until i got to 2nd shop where when i left, came up as oil level too low the ticking/clicking noise is back. Got back home IDrive still said oil level too low ... checked the dipstick oil is right on max or just slightly over.
P.S Last oil change was around 500 miles ago with a new oil level sensor fitted.
				Posted: Thu Mar 06, 2025 1:56 pm
				Sounds like a bad sensor to start with.  You do have to be careful not to overfill though.  Correct on the dipstick is in my experience almost a litre too much.
It sounds like something is running because the engine has stopped.  No idea beyond that unless you can identify exactly where the noise is coming from.
				Posted: Thu Mar 06, 2025 2:20 pm
				by isq000
				X5Sport wrote: Thu Mar 06, 2025 1:56 pm
Oil was done by garage i took the car to,it goes back in first thing tommorow morning.From what you said about oil level ect. is making me paranoid now,its realy hard these days to find a garage with a good rep. and would carrie work out up to standards.
P.S would do a lot of work myself but i am limited space,tool and knowledge wise.
				Posted: Tue Mar 11, 2025 10:17 pm
				by isq000
				Update 2
The culprit was throtle body not functioning properly due to carbon build up.
Symptoms
1.Oil level doesnt show the right readings too low or too high
2.Ocasional rattle over speed bumps or pothooles
3.Rough vibration when you start the car or turn off
4.Blower motor's stoped working
5.Electric ticking as per video atached to first post.
Part changed, car runs smooth can tell the difference on response ect.
Hope this helps someone
				Posted: Wed Mar 12, 2025 5:25 pm
				What on earth was the ticking though?  Throttle valve flap ‘flapping’?  It’s a new one on me anyway.  Quite why that should affect the oil level as well.  They aren’t exactly connected really.  Oil is oil, air is air.
				Posted: Wed Mar 12, 2025 9:44 pm
				by isq000
				X5Sport wrote: Wed Mar 12, 2025 5:25 pm
That's exactly what i thought, all of that made no sense whatsoever. I mean so far (fingers crossed) everything is good, time will tell. If anything changes i'll update the tread.
