F25 heating problem
TrickyMickey
F25 heating problem
Hi I have recently bought a 2013 F25 , and due to the cold weather I have noticed the drivers side of the car does not get hot or even warm . I have checked the fuses associated the heating system , all checked out ok . So decided to take it back to the dealer I bought the car from . He has the dash out and can see the blend motors are working , and even recalibrated them . Has anyone have any experience of this problem . This is my third F25 and havent really had any problems . Any suggestions would be helpful !
TrickyMickey
F25 heating problem
Have picked up the car today from the dealers , the heater matrix has been renewed . This was gummed up , probably because different types of antifreeze has been used . Due to the orientation of the matrix , heat was unable to get to the drivers side !. Obviously a dashboard out job ,and quite a wait for the matrix from BMW , as on backorder !. A good flushing to clean the sysem out , and the correct BMW Antifreeze used to finish off .
F25 heating problem
Glad you’ve got it sorted. The bill must have been frightening though!
A tip with BMWs is to also only use their screen wash. Others seem to result in the pumps getting gunged with bacterial growth.
TrickyMickey
F25 heating problem
I took the car back to a used car dealer , under the sale of goods act . I gave him a chance to put the problem right or I could reject the vehicle . The matrix been changed completely fixed the problem !. No charge ! , just a wait as the matrix was on back order .
F25 heating problem
I'd hazard a guess due to the part being in backorder it's a common enough issue , volkswagen had the same in the passat around 2015/16, they said it was alloy corrosion but it's well known to be a bag of fine crystals they put in the expansion tank rupturing with age and blocking the matrix. No heat in right side too which got worse over time.
