Good evening
I’ve not really used my car since I bought it and apart from upgrade the interior lights I’ve not touched it.
One thing I have noticed though is that it’s quite heavy on steering and it seems to tramline a fair bit,
Could this be down to the 20mm spacers that are fitted or would that not make a great deal of difference??
Car pulls and heavy on steering
Don't know what car it is but my x5 is heavier steering than my e90.
What tires has it got on the front as i found run-flat tires to tramline.
Once you get out of another brand the x5 steering does seem heavy , the spacers will make no difference but id check tyre pressure if its been sitting a while
Chri5v8
Thanks for the replies.
Is the e53 x5 v8.
It’s not using run flats so I’ll double check pressures.
I was thinking it could be spacers as these make everything wider etc. I’ll probably take them off and see how it drives later
Is the e53 x5 v8.
