2010 E70 X5 3.0d - 4BDA Low Pressure Fuel Control
Sm[]key
Post by Sm[]key » Tue Aug 13, 2024 10:05 pm
Got the following error code tonight:
4BDA
Engine stalled after switch on and engagement of reverse gear.
Any ideas?
Fuel Filter / Low pressure pump / Relay?
Post by Alan Gunn » Wed Aug 14, 2024 4:39 am
When did it last have a new fuel filter?.
I would start with the easy one fuel filter and see.
Sm[]key
Post by Sm[]key » Sun Dec 08, 2024 9:39 pm
Update on this one, it turned out to be a failing injector.
Engine just cut out and wouldn't hold revs.
Replaced injector and no more faults.
Post by Alan Gunn » Mon Dec 09, 2024 6:18 am
Glad you got it sorted out.
When i had 2 failing injectors the problem i got was starting it when hot.
Mine was the 3.0d m57 engine.
