What is this ?
Big Bad Boris
What is this ?
Does anyone know what this might be, my missus found it under the front seat of her car. Looks like it’s been cut out from somewhere, you can probably see it had a built in 2 amp fuse. ???
What is this ?
Definitely not a BMW Prt No.
Could be power for a dash cam, radar detector, Satnav or similar maybe?
Big Bad Boris
What is this ?
You may well be correct (it’s not a piece of x3 that’s been chopped off) as the writing on the stickers appears to be Italian, rather than
.. although no doubt parts are made for BMW all over the world.
I peeled off the tape, it’s actually in two pieces that were taped together.
Car has sat nav, so maybe one of the other options you suggest is more likely. I was also thinking maybe a permanent attachment for a trickle charger or something… but don’t think that would have a fuse.
