One pressure for all tyres?
- Xman
I use one pressure "34psi" for all tyres in my E53 D-Sport but someone has suggested me something else. Is it a normal thing to use different pressure for front and back tyres?
- StuBeeDoo
Absolutely! In nearly 60 years of motoring, I've only ever known one car that had recommended pressures the same for front and rear. ........And that one's a Citroen C4 Picasso.Xman wrote: Fri Jul 26, 2024 2:52 pmIs it a normal thing to use different pressure for front and back tyres?
Your car should have a label on one or other of the door pillars with what BMW recommends.
My X6 has a single pressure unless loaded, though it depends upon tyre sizes as well. With the 20” set it’s either 32 or 34psi from memory, but the 19” set it’s different - can’t remember what though, and those were for winter rubber. It is the only BMW I’ve owned where they are the same though.
There should be a pressure plate in one or other of the door pillars.
Never anthropomorphise computers. They hate that.- Alan Gunn
I have put the same 34psi all round on my e53 for the last 7 years now.
Tyres have worn perfectly in fact only just changed a set after 6 years.
Onlinelezmtaylor
I also put 34psi all round. Have had my 4.4 E53 since 2006 .
Lez
Lez
