Sticking caliper v's pad wear countdown
Posted: Fri May 24, 2024 12:55 pm
I've had a slightly sticking front caliper since the x5 got back on the road ,its been fine most of the time or so it seemed , I got a refurbed caliper last week and had a look at the outer pad on drivers side and it looked almost new so didn't buy new pads , once the caliper was off it became clear the inside pad was right down to the metal with about a piece of paper thickness of pad and had rubbed the end of the pad locator too.
The check control told me I had another 47,000 miles remaining !( I've already done 41,000 miles on these pads
) the problem is the wear indicator its on the passenger side and this was the drivers side so went undetected , Its not easy to see the inner pad without the wheel off so a bit of a pain but always assume you will need pads . The disc it seems is thankfully ok . I went to collect new pads and asked to see in the box at the motor factors and it turned out the box was right but it had the wrong size pads in it
so they had to reorder ,in the end I put an old pad I had sitting in a spare caliper in to get mobile again till the new ones arrived
I took the pistons out and the teflon coating ? if that's what it is had worn though and it had a ring of rust on one pot only causing it to stick and yes tha'ts the friction side not the back
