Continuing on my post about BMW workmanship being abysmal, if you have your car serviced by a main dealer, don't think they do a proper job.
You would think that part of the servicing would be putting stuff back with lubricant or grease as required.
To me part of that would be refitting wheels with a touch of non seize at the contacting points. Apparently not, with the result that the wheels needed persuading with a soft hammer to remove from the location spigot.
I guess all proper mechanics are now retired, the technicians are now in control...
Wheel Hub Corrosion
Wheel Hub Corrosion
Only the wheel centring ring itself is supposed to have any lubrication. The official instructions are that the mating surfaces should be cleaned to ensure no dirt, grease or debris lies between the surfaces. BMW even have a special tool to ensure this is done - they would wouldn’t they!
Wheel Hub Corrosion
........And technicians are on productivity bonuses, so they don't spend one minute more than they have to on any given vehicle.IanP wrote: Sun Apr 14, 2024 6:46 pmI guess all proper mechanics are now retired, the technicians are now in control...
Not so long ago I worked in a (not BMW, admittedly) dealership, and we had one particular tech. who regularly carried-out 4 services in the time he was allocated to do 3. Then the company temporarily re-structured the bonus system and for a few weeks his output inexplicably dropped by 25%.
OnlineIanP
Wheel Hub Corrosion
I agree, maybe they need a tool and a procedure to do the centring ring correctly. Or technicians who understand how to service a vehicle correctly and why it should be done a certain way. And no bl%%dy coppaslip. Better anti seize greases are available. Rant overStuBeeDoo wrote: Sun Apr 14, 2024 7:47 pm Only the wheel centring ring itself is supposed to have any lubrication. The official instructions are that the mating surfaces should be cleaned to ensure no dirt, grease or debris lies between the surfaces. BMW even have a special tool to ensure this is done - they would wouldn’t they
Wheel Hub Corrosion
Special tool is a wire brush lol
if you want it done right ya gotta do it yourself
it was £20 to check/ top up your oil last time I was in for the airbag recall .
Wheel Hub Corrosion
But it’s a very ‘special’ wire brush. You can’t go using a ‘normal’ wire brush on the ultimate driving machine now can you!
/cynic mode off
/cynic mode off
