Front Parking Sensor Fault
Discuss anything to do with the BMW X1 (F48). Problems, How To Articles & Performance topics can currently be discussed here also.
TivvyMatt
Post by TivvyMatt » Fri Dec 29, 2023 3:00 pm
Hi all. When engaging reverse gear, one of my front sensors thinks it's next to something (when it isn't). It's a continuous sound, so it thinks something is *very* close. It doesn't tend to happen when it's raining.
I've just been quoted £159 by BMW for a diagnostics check then of course, there could be a another cost to fix.
Has anyone on here had this issue, or have any ideas on how to fix it?
It's a 69 plate X1.
Thanks in advance!
Post by X5Sport » Sat Dec 30, 2023 9:22 am
Depends upon which sensor? The outer ones may be part of the fog light trim, in which case that needs to come off and it’s a simple swap. If it’s an inner one then the bumper needs to come off and then again it’s a swap out for the transducer.
Sounds like BMW Diagnostics have got even more pricey!
TivvyMatt
Post by TivvyMatt » Mon Jan 01, 2024 7:11 pm
X5Sport wrote: Sat Dec 30, 2023 9:22 am Depends upon which sensor? The outer ones may be part of the fog light trim, in which case that needs to come off and it’s a simple swap. If it’s an inner one then the bumper needs to come off and then again it’s a swap out for the transducer.
Thanks for the reply. Yes, not cheap that's for sure!
