Back ground
GT456!
Back ground
Post by GT456! » Wed Jul 26, 2023 5:56 pm
Can you add the option to have the screen back ground black with the letter normal wht?
Back ground
Post by X5Sport » Wed Jul 26, 2023 6:03 pm
For the forum or in a car?
GT456!
Back ground
Post by GT456! » Wed Jul 26, 2023 6:08 pm
Yes...the forum
Back ground
Post by X5Sport » Wed Jul 26, 2023 6:16 pm
I’ll ask Sp3ctre if dark mode is supported.
GT456!
Back ground
Post by GT456! » Wed Jul 26, 2023 7:29 pm
☝Yep yep!
That's the term "Dark mode".
And thanks for your assist :thumbsup:
Back ground
Post by sapphireblack » Fri Jul 28, 2023 11:11 am
You can easily set your device to Dark Mode. Everything here and elsewhere will then be white on a black ground.
Back ground
Post by X5Sport » Fri Jul 28, 2023 12:04 pm
It depends…..not all devices will recognise dark mode or default to it if not supported. My iDevices are all in DM but this (and most other websites) don’t use it so are in ‘normal’ mode. For me I think that Safari browser is the issue
Back ground
Post by sapphireblack » Fri Jul 28, 2023 12:20 pm
Oh. FWIW my Samsung device offers Dark Mode from the top drop down menu
Back ground
Post by X5Sport » Sat Jul 29, 2023 2:52 pm
I’ve checked with Sp3ctre and the forum theme doesn’t support Dark Mode natively, most don’t without significant recoding. Depending upon the platform you are using though, there are add-ins for browsers that convert ‘normal’ to DM. I use one called Dark Reader for use with Edge. Firefox has one as well. There are probably similar ones across other browsers.
