iPod leads
iPod leads
I appreciate that I'm something of a dinosaur but still like my taste in music played from an iPod. To date, I've only used classic or touch models utilising the 30pin lead supplied with the car.
My question is, was there ever a later version for the lightning plug connection. Track info is handy on the cars display, and aftermarket leads seem not to offer this function.
** Well it seems like BMW offered one, part # 6112240801. None tor sale i can find after a quick search though.
Lobster Pot
iPod leads
Not sure what car or system you got but can’t you connect using Bluetooth?
iPod leads
Yes there was. 5th Generation iPod ‘Touch’ and newer are all lightning connector type beginning from 2012.
iPod leads
Bluetooth streaming came in for the model year 2011 X6, and possibly the late MY2010 built X5. Before that you needed a ‘Y’ cable that connected to the headphone socket and then to the car Aux + USB. Only worked if the car was optioned correctly. My Oct 2010 built (MY2011) X6 got the newer CIC iDrive and that supported it. The earlier CCC type didn’t (though I believe places like Cartronics will update the relevant module for you). The E70 got the CIC drive slightly earlier.Lobster Pot wrote: Sun Jul 09, 2023 8:37 pm Not sure what car or system you got but can’t you connect using Bluetooth?
Option code SA6FLA - Audio/USB Interface was required.
Y-cable adapter is part number: 61122408012
iPod leads
Yes i could but i dont think a Bluetooth connection provides the track info, etc.on the monitor.
iPod leads
My 2009 car supports the 30pin Y cable connection. I'm thinking i might 'upgrade' to a later generation iPod touch model. No point in having less features though.X5Sport wrote: Sun Jul 09, 2023 8:43 pmBluetooth streaming came in for the model year 2011 X6, and possibly the late MY2010 built X5. Before that you needed a ‘Y’ cable that connected to the headphone socket and then to the car Aux + USB. Only worked if the car was optioned correctly. My Oct 2010 built (MY2011) X6 got the newer CIC iDrive and that supported it. The earlier CCC type didn’t (though I believe places like Cartronics will update the relevant module for you). The E70 got the CIC drive slightly earlier.Lobster Pot wrote: Sun Jul 09, 2023 8:37 pm Not sure what car or system you got but can’t you connect using Bluetooth?
iPod leads
As above…..lightning cable/USB = Y-cable adapter is part number: 61122408012
Still listed as available though non-genuine.
Lobster Pot
iPod leads
I wasn’t sure what car or system they had my music from my phone is connected through Bluetooth and all info from it is on the idrive screen and all controlled from steering wheel or through voice when it can understand what I’m asking it
iPod leads
So far, the sellers of non genuine have all confirmed no data transfer. Only charging and playback.X5Sport wrote: Sun Jul 09, 2023 8:53 pm As above…..lightning cable/USB = Y-cable adapter is part number: 61122408012
iPod leads
As above in my older car, with the exception of data transfer.Lobster Pot wrote: Sun Jul 09, 2023 9:00 pm I wasn’t sure what car or system they had my music from my phone is connected through Bluetooth and all info from it is on the idrive screen and all controlled from steering wheel or through voice when it can understand what I’m asking it
iPod leads
You should have about 20GB of hard drive space with the CCC drive. It’s not a huge amount I know, but might be an option?
iPod leads
Thanks for that.
I've always been happy with the 30pin Y lead arrangement. If i move up to a later model iPod, i just want the same facility but with the lightning plug option. I like that its basically fit and forget, and the I-drive assumes command.
I'll find one eventually. I've asked BMW UK, but would probably have to donate a kidney if they still have any
iPod leads
It seems Apple made a 30pin to lightning adaptor, £40 for a little adapter from most sellers
BUT, it doesn't transfer data anyway
iPod leads
If it has ‘MFA’ (Made for Apple) certification that pretty much guarantees doubling the price.
iPod leads
I'll wait on BMWs response. They're not in a rush though
