2010 E70 X5 3.0d - Intermittent No Boost
Sm[]key
Post by Sm[]key » Fri Apr 28, 2023 7:30 pm
Clocking a lot of miles weekly.
Every now and again, usually after when cruise control has been set for speed camera zones I accelerate and no boost kicks in.
This corrects its self after a few miles?
Current Error Codes:
  • 4667 Particle Filter System
    452A Info - Particle Filter System
    4501 Exhaust gas circulation control deviation
    4507 Exhaust gas circulation control deviation
    3F40 Rail Pressure Senor offset test
    4222 Cylinder 2 control
Post by X5Sport » Fri Apr 28, 2023 7:43 pm
Has it had the swirl flaps removed? Several reports that 4667 is the DPF regen happening too frequently and 452A that the DPF is end-of-life. Both can be caused by swirl flap deletion but only show up many thousand of miles later.
Sm[]key
Post by Sm[]key » Fri Apr 28, 2023 7:53 pm
Swirl Flaps still there.
I also have a blue tooth OBD, if I reset all the error codes the boost comes back.
Post by Leslie » Fri Apr 28, 2023 10:21 pm
The Dpf end of life wont cause any running issues as long as the dp isf still working its just an annoying warning that appears after 10 mins . Can you run a smooth running test as it sounds like injector 2 is having trouble but I think the egr can cause problems if its stuck open too.
Post by X5Sport » Sat Apr 29, 2023 7:30 am
That one root cause eliminated then. As above, injector two not happy and the EGR with it.
Sm[]key
Post by Sm[]key » Tue Jun 18, 2024 4:32 pm
This was a 4507 fault for anyone interested.
Clear fault and turbo returns
Still not sorted.
Post by Leslie » Thu Jun 20, 2024 2:13 pm
The egr coolers have a habit of leaking plus there is a return spring underneath that breaks from what I've heard and will stop it closing properly so id check for that , it sounds like the egr isn't closing causing no power .
