2010 E70 X5 3.0d - 3F40 Rail Pressure Sensor Offset Test
Sm[]key
Post by Sm[]key » Fri Apr 28, 2023 3:07 pm
Currently getting the following error code along with a number of others:
  • 3F40 Rail Pressure Sensor Offset Test
The idles is sometime very lumpy, and more recently the car with cut out at low revs, very dangerous at roundabouts.
I presume I need to change the pressure sensor unless this code points to something else?
Post by X5Sport » Fri Apr 28, 2023 6:43 pm
A quick search on line indicates either the sensor or bad wiring/connector to it. Seems a fairly common problem.
Sm[]key
Post by Sm[]key » Fri Apr 28, 2023 7:21 pm
Quite costly, gone for a second hand one. Beware with peril!
