Fuel inject.system - Temperature gauge goes crazy
Posted: Fri Nov 04, 2022 9:51 am
				Hi all
My Fuel inject.system warning comes up when I try to start my car and at the same time the temperature gauge shoots right up to extreme hot. The car won't start at this point, however if I turn the ignition off and on a few times until the warning doesn't come up, it starts no problem at all. At first I only needed to turn the ignition off and on a few times, but its getting worse and takes more tries now.
At first I thought it was a glow plug issue since a diagnostic indicated the plugs. I have changed these and it did not fix the issue.
After reading a few other posts, I now think its a fuel pump? But with the temperature gauge going up and down I assume its to do with wiring.
Has anybody else had of have heard of the same problem?
