Parking sensors sound
Underfelt
The beep sound for the pdc has stopped working.
I have had a diagnosis and there was no fault.
I have bought a new module and swapped and still nothing.
I have had the sensors tested and they all work fine I just don't have any sound.
I dont have the original head unit. I have a pioneer installed.
All was working fine until a week ago and now nothing.
Any ideas??
Any ideas??
Underfelt
I'm not sure.
Does pdc have a separate speaker?
If so where would it be located?
Reverse lights working ????.
Just a thought switch for them fail.
Underfelt
Yes. Reverse lights work. And sensors all.work it's just the beeper that's stopped. Not sure where the speakers are located to test them.
- marti
The PDC on the e70 uses the stereo speakers so you have 4 as far as Im aware.
Underfelt
All the music and warning tones still work.
So I assume there are separate speakers for the pdc?
- marti
Ive found a wiring diagram and it shows the wiring is all to the speakers.....page 6 in link below:
https://www.xoutpost.com/pdf/e70/05c1_E ... ontrol.pdf
Underfelt
Thank you very much ill have a look, see if I can figure it out.
