Track rod assembly
approved
Track rod assembly
Post by approved » Mon Oct 18, 2021 10:07 am
Morning
After waiting for an age to get lemforder track rod assembly's from Euro, I have ended up buying some Meyle ones instead
The ones on the car are seized, so cant be adjusted, so having gone to the tyre place to get them put on and aligned, they are saying they dont have the socket needed for the rod end bolt ( they did have but its not there....just my luck)
Anyone know the 12 sided socket size required? They had 30 and 27, but reckon its 28 and having rung snap on in front of me, they are quoting a few weeks minimum, so I've said I will try and find one for the job which they can fit in quickly once found.
Can anyone confirm that it is actually 28 and not 29?
Saves me buying both.
Track rod assembly
Post by henrym3 » Wed Oct 20, 2021 11:01 pm
I’ve just fitted these today, Needed a 21mm and 22mm. At the rack end I used a monkey wrench and experience to not over/under tighten. They are MEYLE as well.
approved
Track rod assembly
Post by approved » Thu Oct 21, 2021 1:52 pm
Thanks for the reply, turns out these ones are in fact 27 ( different rod end nut to those)
I did a load of research, ended up speaking to Meyle and they said defo 27. Went back, tried the 27 again and it went straight on.
Lol. Going back in on Tuesday for fitting and alignment and hopefully thats me done for another while...
H4MP
Track rod assembly
Post by H4MP » Sun Oct 31, 2021 1:52 am
Meyle parts are good, I used Meyle lower and upper arms, been over 2 years so far so good
approved
Track rod assembly
Post by approved » Sat Dec 18, 2021 6:39 pm
Track rods changed, geo done.
Car drives straight as a die.
Track rod assembly
Post by X5Sport » Sat Dec 18, 2021 6:50 pm
Success :D :D
