Drop links - Lemforder or Meyle?
cooa99
After receiving my car back from the indy to fix an a knocking issue I am having up front, they came back with a long list of suspension related issues I am not aware of, most of them at the back. So they replaced worn control arm bushes they spotted but noise is still present to which they said would be the drop links.
Youtube video shows this is a not a big job to do so I'll give this a go myself now that I have replaced my trolley jack.
Should I use Lemforder or Meyle drop links?
Since the indy has check the car over (and hopping they have not missed anything), I was wondering if there is anything else I should replace while the front is up in the air. I won't attempt anything with ball joints as I understand its not an easy thing!
Current Cars BMW 2005 X5 3.0d ; Golf 2003 1.9 TDI for the High Miles Journey to work
- StuBeeDoo
Personally, I'd use Meyle.
- henrym3
Lemforder are a recognised OEM supplier and generally are more expensive. Meyle are also a top brand and you certainly won’t go wrong with either.
Have used both brands and the only 2 id usually consider now for most things
I use Meyle if i can get the part.
cooa99
gone with Lemforder in the end since. I could pick that up today and fit while the weather is good instead of waiting for Meyle from ebay which could take over a week.
Do the drop links have to be tightined under load or ok in the air?
- StuBeeDoo
If they're ball-joints, in the air is fine. Rubber bushes need to have the weight of the car on the wheels.cooa99 wrote: Wed Sep 15, 2021 9:35 amDo the drop links have to be tightined under load or ok in the air?
cooa99
thanks, I just hope its turns out to be an was job.
cooa99
Always my luck
I can't get the drop links off. I need a really flat 18mm open end wrench which I can't find anywhere
- henrym3
I ended up taking an angle grinder to a spare 18mm and making it a bit thinner to fit in there. It was an old open ended that comes with the BMW toolkits
cooa99
unfortunately, i don’t have a grinder but i do have a dremel.
Another option I am looking at is a bicycle cone spanner if i can find one tomorrow
- Greydog
I use an old Bicycle spanner file to fit tapped in place cable tie to drop link undo nut, repeat other end.
cooa99
It turned out to be a horrible job. I could not find a bicycle spanner so used my Dremel to grind down a spanner.
I tried with that but the bolts were just to tight even though it opened a little. Also once loose the thin spanner to hold the back steady just kept coming off. 3hrs later I used the Dremel to cut the bolt off. I wished I had done that from the start. I must have gone through 7 metal discs.
