stripped oil drain plug
Posted: Fri Apr 02, 2021 4:08 pm
by Loperamide
Any ideas on how to take out a stripped oil drain plug (stripped inside allen hex and outer socket hex)
Re: stripped oil drain plug
Posted: Fri Apr 02, 2021 9:11 pm
by Leslie
Hammer a torx bit into the stripped Allen should grip enough to unscrew then or buy an oil sucker and take the oil out the dipstick
Posted: Fri Apr 02, 2021 9:18 pm
by henrym3
That must be tight. If I understand the shape of the plug you describe then use a monkey wrench, failing that you’ll have to take off the sump but that will be messy with all the oil still in but you’d probably fair better on a bench
Posted: Sat Apr 03, 2021 7:18 am
by Alan Gunn
+ 1 on the torx bit method.
Posted: Sat Apr 03, 2021 9:57 am
by marti
Small pair of Stillson's will grab the hex and undo it no problem....
Posted: Sat Apr 03, 2021 11:17 am
by Loperamide
henrym3 wrote: Fri Apr 02, 2021 9:18 pm
https://www.amazon.co.uk/febi-bilstein- ... 381&sr=8-4
Its basically like the one in the link, but stripped both inside and outside. And there's not width to grab onto it on the outside where a socket wrench would go. I tried locking-jaw pliers but it kept slipping off.
Posted: Sat Apr 03, 2021 11:20 am
by Loperamide
marti wrote: Sat Apr 03, 2021 9:57 am
is that one of those pipe wrench's? There is not much space through the hole in the stiffening plate, and if locking-jaw pliers didn't work then there is no hope for a pipe wrench
Posted: Sat Apr 03, 2021 1:04 pm
by Greydog
You could take off the stiffening plate that would let you get Stilson's in
Or you could try another plumbers tool a Basin Wrench same locking action as the Stilson but designed to use in tight spaces.
Keep the Stilson handy to bash whoever butchered the plug in the first place, as it is destroyed in side and out they must be a determined butcher
Oh and get a new sump plug first would be my thoughts
Posted: Sun Apr 04, 2021 5:56 am
by Alan Gunn
Posted: Sun Apr 04, 2021 7:37 am
by Greydog
How about a surface drive socket they are designed just for this eventuality ?
Or in desperation drill through the centre of the plug and once the oil has drained use a stud extractor to remove the plug drop the sump clean and refit with new plug.
Out of ideas now
